Android Lurker
Installation Problem
Hi...I am new here n its my first post tooo.....
I hav downloaded application like facebook, yahoo,mig from google play n application doesnt store in sd card..even i have apps2sd application to move applications to sd.what if have some other ideas to store those application esp. Facebook.kindly need ur replies.
Sent from my GT-S5570 using Android.net
05-04-2012 12:45 AM
# ADS
Super Moderator
Depending on your exact phone and circumstances, you may not be able to move system apps to your SD Card. I'm not a technician so I can't really advise you or walk you through anything, so I'm going to ask you to be patient and hang on for awhile until one of our Rescue Squad guys can swing by and give you a hand.
Super Moderator
Some applications don't have the function to install them to SD card. They'd probably not work perfectly on SD card. But it's all on the developers.
Of course, if you'd root your phone, you'd gain the ability to move any app to SD. (If you'd consider to root your phone, I highly recommend you read more about root access and listen to all the warnings.)
When people run in circles,
it's a very very mad world.
Tears for Fears
Super Moderator
Originally Posted by
UltraDroid
I ask you again, what difference does it make? :D
Tears for Fears
Android Lurker
Thnk you guys..for being so co-operative with this....ok may be there's depending with the developers....what if I install? snaptu's beta to have facebook..will i get tht n install to sd card n will that works??
Super Moderator
djlinkinheart
Sorry, I don't understand you clearly.
Are you asking, if a different Facebook client can have the feature to install on SD card? If so, then yes, some clients can have the feature.
Tears for Fears
Android Lurker
Yah ..I was asking if there s some other facebook application is available there..nyway I got ur words.Thnks for being with me.
Super Moderator
My pleasure.
Tears for Fears
Android Lurker
You need to establish root access. I have my Facebook app(s) on my SD card and they run fine. I had to take control of the OS by rooting the phone in order to do it. I'm also using synergy Rom and its working great!
Sent from my PC36100 using Android.net
Android Lurker
Thnk you sooo much for ur lovely advice..n I did whatever u said n really it works ..I rooted my ph n hav the administration access..now I can easily move applications to sd card.Thnks you guys.
