Help??
This is a discussion on Help?? within the Android 2.3 forums, part of the General Android OS category; I am having a problem where apps get "erased" from my sd card. For example, if angry birds rio got "erased" it would turn to ...
Thread: Help??
    Android Lurker shockwave72's Avatar
    Jun 2012
    Help??
    I am having a problem where apps get "erased" from my sd card. For example, if angry birds rio got "erased" it would turn to this: com.rovio.angrybirdsrio, making me unable to use the app. It has not happened in a while, but I wanted to be prepared in case it did.
    Sent from my DROID3 using Android.net
    Super Moderator Tears_for_Fears's Avatar
    Apr 2012
    196 times
    Are you using any kind of storage memory cleaner? Because apps shouldn't be erased by themselves. Also, are you sure they're erased? Maybe they're just not mounted properly.
    When people run in circles,
    it's a very very mad world.
    Tears for Fears
    ~~~ Guidelines of Conduct ~~~
    Jun 2012
    Nope, no storage memory cleaner. And it is mounted correctly, because apps on internal storage never get erased. I've even tried formatting the sd card, but the problem is still there. As I said, I want to be prepared if it happens again.
    Jun 2012
    Any suggestions on what the problem is?
    Apr 2012
    196 times
    I meant SD card. Internal storage has nothing to do with it. Does everything load from SD when the apps get erased? If it does, I'm not sure what could cause this.
    Tears for Fears
    Apr 2012
    196 times
    After it gets erased, you have to install it again or does it come back later?
    Tears for Fears
    Jun 2012
    After it gets erased I have to install it again.
