Connection Between Android 4.0.4 and PC
This is a discussion on Connection Between Android 4.0.4 and PC within the Android 4.0 forums, part of the General Android OS category; hello community, i bought Android 4.0.4 yesterday and i have a difficulties of connection with any pc then i use at home..when i connect i ...
Thread: Connection Between Android 4.0.4 and PC
    Android Lurker mario45's Avatar
    Sep 2013
    hello community,
    i bought Android 4.0.4 yesterday and i have a difficulties of connection with any pc then i use at home..when i connect i donmt see any notification on my pc..
    Start next computer i couldn't get my Android, please can you help me?
    Android Jr Member RealCatfish's Avatar
    Mar 2012
    Where ever I lay my head.
    I would like to know what you're running Android 4.0 on what device what manufacturer and I also would like to know what kind of computer you're using and what operating system is on it and then I could probably help you with figuring out your problem
    May 2012
    Lost In The Internet
    87 times
    It's a bird
    What's your device?
    - Have you install driver on your PC
    Unsure? Use AirDroid: https://play.google.com/store/apps/d...airdroid&hl=en
    Welcome to the forum
    TapaTalking from Republic™ Of Android
    Super Moderator cali's Avatar
    Sep 2011
    329 times
    Welcome to the site. Hope you get this resolved.
    Sep 2013
    good morning,
    Please i have one Android 4.0.4 since 2weeks and i couldn't connect it with my pc Hp...when i connect it i don't see any notification that my peripheric is visible so please help me..
    thank you.
    Super Moderator rayhodge02's Avatar
    Sep 2011
    14 times
    Quote Originally Posted by mario45 View Post
    good morning,
    thank you.
    Do you have the correct driver installed
    Sent from my SCH-I605 using Tapatalk 2
    Android Lurker HunkGates's Avatar
    Jan 2014
    good morning,
    thank you.
    Have you solved your problem? If not, I advise you to install a proper Android USB driver on your PC if you connect your phone and computer by USB cable. Moreover, because there is no more information about your device (e.g. brand, model number, etc), I have no other choice but to offer you several websites where you may be able to download an appropriate driver and they are:
    androidicloud.blogspot.com/2014/04/android-usb-driver-for-samsung.html
    androidicloud.blogspot.com/2014/04/motorola-usb-drivers-for-android-phones.html
    androidicloud.blogspot.com/2014/04/lenovo-android-usb-drivers.html
    Besides, you need to turn on USB debugging according to Menu/Settings/Developer options/USB debugging.
  1. No Connection HELP!!!!!
    By Awol in forum Rescue Squad Help
    Last Post: 09-07-2012, 11:26 AM
  2. Android A2DP connection through program
    By chinnadurai.d in forum Android Forum
    Last Post: 06-16-2011, 08:39 AM
  3. Android Market Causes My N1 to Loose 3G Connection
    By shizane101 in forum Nexus One
    Last Post: 04-16-2010, 12:00 PM
android 4.0 4 usb driver download
android 4.0.4 connect pc
android 4.0.4 connect to pc
android 4.0.4 driver for my pc
android 4.04 to pc connection
android pc connection
android usb connection settings on 4.0.4
connect android 4.0.4 to pc
how to connect android 4.0.4 to pc
how to connect internet from pc to android 4.0.4
how to connect usb android mobilr
pc android 4.04 connect
problem on sco connection between android
usb driver for android 4.0.4
where can i get connections on my samsung 4.0.4 tablet
