Can Two Bluetooth Head Sets Be Paired with Single Phone?
This is a discussion on Can Two Bluetooth Head Sets Be Paired with Single Phone? within the Android Audio forums, part of the Android Discussions category; Hello, Iam trying to pair 2 BT headsets with android phone so that when phone rings 2 persons can simultaneously listen or speak on 2 ...
Thread: Can Two Bluetooth Head Sets Be Paired with Single Phone?
    Android Lurker Miscuser's Avatar
    Apr 2013
    Hello,
    Iam trying to pair 2 BT headsets with android phone so that when phone rings 2 persons can simultaneously listen or speak on 2 different BT sets?
    Super Moderator tuxedo's Avatar
    Nov 2012
    Nashville, TN
    49 times
    Do not personally use bluetooth much and never tried to pair 2 BT headsets simultaneously, but welcome to the forum!
    Super Moderator CR6's Avatar
    Idaho
    222 times
    Welcome to the forum!
    You won't have a problem pairing two different BT headsets to your phone, but I don't believe you can use them simultaneously.
    How often would you need this feature? I would think simply putting it on speaker phone would be the better option.
    Well, all you can do it get them paired and try it out. I'd be interested to know if this works.
    Good luck!
    tap'n
    Apr 2013
    Tux edo and CR6
    Thanks for the warm welcome...
    CR6: I completely agree with you switching loud speaker is better option and so on...But what i was trying is for sake of testing and for fun....nothing more than that...
    I tested my self and understand we can not use both BT headsets at same time as we canot connect 2 BT headsets same time.
    Android Lurker DivenParker's Avatar
    Apr 2016
    Maybe not
  1. Replies: 1
    Last Post: 03-18-2013, 11:18 AM
  2. Replies: 0
    Last Post: 02-02-2012, 11:24 AM
  3. Bluetooth paired but not connected - and won't!
    By tiaza in forum Nexus One Tech Issues / Bug Reports
    Last Post: 08-27-2010, 12:05 AM
  4. Bluetooth contacts sharing to Pioneer car head unit
    By Evman in forum Nexus One Tech Issues / Bug Reports
    Last Post: 08-05-2010, 06:40 PM
  5. Does bluetooth sleep when not paired?
    By DubVBenz in forum Nexus One
    Last Post: 01-30-2010, 06:42 PM
can 2 same wireless headsets be paired with same android phone?
can a bluetooth be paired to two phones
can droid mini use 2 bluetooth head sets at the same time
can i connect two bluetooth head sets to single laptop
can multiple bluetooth headsets be paired to android tablet
pair 2 or more headsets to android tablet
pair two bluetooth headsets android
two headsets android
