Using Earphones With Device's Own Microphone
This is a discussion on Using Earphones With Device's Own Microphone within the Android Audio forums, part of the Android Discussions category; I have the original samsung earphones but for some reason the microphone (in the earbuds) seems faulty. I want to know if there is a ...
Thread: Using Earphones With Device's Own Microphone
    Android Lurker mikespider's Avatar
    Sep 2015
    I want to know if there is a way to have the earphones connected to the device and use the device's own microphone instead of the earphones mic simultaneously.
    Device: Samsung Galaxy S3 Neo
    Thanks
    Banned Metur1987's Avatar
    Sep 2015
    Yes, if you get an earphone without mic, it may be possible to use the way you like it, but still I am not sure about it you could give it a try.
  1. Can you make Navigation work with earphones?
    By Woolfold in forum Samsung Galaxy Ace
    Last Post: 07-10-2013, 09:39 AM
  2. No Sound Through Speaker, Earphones Work Fine
    By shhh_on in forum HTC EVO 4G Tech Support
    Last Post: 10-23-2012, 09:43 AM
  3. Replies: 2
    Last Post: 04-27-2011, 04:59 PM
  4. Lady sized earphones?
    By JillKeats in forum Nexus One Accessories
    Last Post: 12-10-2010, 08:07 PM
  5. Any tips on new in-earphones?
    By elvis1 in forum Nexus One Accessories
    Last Post: 05-18-2010, 05:15 PM
