Auto BT connect and play
This is a discussion on Auto BT connect and play within the Android Audio forums, part of the Android Discussions category; I don't know if ADW EX would let you do it, but you might be able to set up a custom shortcut or macro-type thing ...
Results 11 to 14 of 14
Thread: Auto BT connect and play
    197 times
    FurryVarmint
    I don't know if ADW EX would let you do it, but you might be able to set up a custom shortcut or macro-type thing that would do all that for you. I know with ADW free you can set up shortcuts that would cut down on the number of presses you'd need -- and a widget from the market to turn BT on and off so you don't need to keep digging for it.
    DO NOT WRITE IN THIS SPACE
    Android Lurker ed4heights's Avatar
    Jun 2011
    I'll keep plugging away at it.
    Appreciate your help
    Jun 2011
    WIN for the Geeks!!
    I used a combination.
    Bluelaunch, which in turn launches Pro Amp. Pro Amp has a nifty little setting that will autoplay on connection to an A2DP device.
    197 times
    FurryVarmint
    Cool! Sorry I couldn't be more help, but really glad you solved the issue!
  1. Replies: 5
    Last Post: 06-02-2011, 03:53 PM
  2. Android auto connects to wifi but I don't want that
    By hargon in forum Android Forum
    Last Post: 03-21-2011, 09:05 PM
  3. Facebook Connect Button
    By Vulcan1600 in forum Introductions & Site Assistance
    Last Post: 01-16-2011, 11:23 PM
  4. can we get auto correct for texting?
    Last Post: 11-18-2010, 08:30 PM
android bluetooth auto connect
android bluetooth auto play
bluetooth how to get galaxy s2 to sync automatically
connect to two bluetooth devices at once tasker
tasker bluetooth auto connect
tasker bluetooth button
tasker bluetooth connect
tasker bluetooth connect in car
tasker bluetooth connected
tasker connect bluetooth
tasker connect to bluetooth device
tasker play music bluetooth
tasker play music when connected to bluetooth
tasker, bluetooth connect
turn on bluetooth automatically using tasker when in car
