Auto BT connect and play
This is a discussion on Auto BT connect and play within the Android Audio forums, part of the Android Discussions category; Dear Gurus, Button tapping being the bane of my life, I seek a simple solution. I've just got my hands on a stock Sammy GSII, ...
Results 1 to 10 of 14
Thread: Auto BT connect and play
    Android Lurker ed4heights's Avatar
    Jun 2011
    Dear Gurus,
    I've just got my hands on a stock Sammy GSII, unavailable in Arabia for the next four months. It's impressive.
    Here's my wish:
    I want to arrive home, and hit one widget on my homescreen that will automatically pair with a Bluetooth device (home theater) and start playing music.
    One tap, nothing more.
    Obviously, I will set my connection notification as 'Welcome home Sir. Cue music'
    Discuss.
    Any and all input is appreciated.
    Many thanks.
    197 times
    FurryVarmint
    I have absolutely no use for this, but I want to see it happen simply because it'd be cool and awesome and full of win. :D
    Once paired with a device, your phone won't forget said device unless you tell it to or something major glitches, so that part of it should be relatively easy. The next question would be have you looked at Tasker to see if it can do what you want?
    DO NOT WRITE IN THIS SPACE
    Jun 2011
    I did not know about Tasker. I was going down the route of 'Bluetooth connect' apps, hoping to tweak the settings and add a shortcut.
    Tasker looks pretty robust though. I'll have a solid play with it later .
    Many thanks, I'll let you know how I get on.
    197 times
    FurryVarmint
    Please do. I'm sure you're not the only person to want something like this. I hope it works!
    Jun 2011
    I may have a compatibility issue, and of course my credit card is still in the pub.
    Modern life is so hard.
    Ed.
    Jun 2011
    It didn't work.
    Is there not a simple app/shortcut to just connect and play?
    Daddy, please don't make me download iTunes, it hurts bad.
    197 times
    FurryVarmint
    iTunes won't work with Android anyway.
    Is your system broadcasting Bluetooth all the time?
    Jun 2011
    My home entertainment system is always on, and ready to connect to a Bluetooth audio source.
    The nearest I've gotten is:
    Open player
    Choose track
    Menu
    Play Through Bluetooth
    Turn on Bluetooth
    Connect
    I should've explained the iTunes thing. I could, in theory, buy a nano, dock it in my surround system, an set up a mirror to bounce the IR signal from the remote control to the theaters sensor and press PLAY as I come in, but that would mean going over to the dark side.
    197 times
    FurryVarmint
    Would connecting first help? Or are you saying that the steps outlined in your post worked?
    Jun 2011
    I can't connect until I get in the front door. Those are the six button presses that will fill the house with music, but surely there's a quicker way?
  1. Replies: 5
    Last Post: 06-02-2011, 04:53 PM
  2. Android auto connects to wifi but I don't want that
    By hargon in forum Android Forum
    Last Post: 03-21-2011, 10:05 PM
  3. Facebook Connect Button
    By Vulcan1600 in forum Introductions & Site Assistance
    Last Post: 01-17-2011, 12:23 AM
  4. can we get auto correct for texting?
    Last Post: 11-18-2010, 09:30 PM
android bluetooth auto connect
android bluetooth auto play
bluetooth how to get galaxy s2 to sync automatically
connect to two bluetooth devices at once tasker
tasker bluetooth auto connect
tasker bluetooth button
tasker bluetooth connect
tasker bluetooth connect in car
tasker bluetooth connected
tasker connect bluetooth
tasker connect to bluetooth device
tasker play music bluetooth
tasker play music when connected to bluetooth
tasker, bluetooth connect
turn on bluetooth automatically using tasker when in car
