No Loud Speaker :((
This is a discussion on No Loud Speaker :(( within the Android Audio forums, part of the Android Discussions category; What should I do, I only here music and everything if I will use headphone, when I'm going to use the loudspeaker there is nothing ...
Thread: No Loud Speaker :((
    Android Lurker glennbernal's Avatar
    Feb 2012
    No Loud Speaker :((
    What should I do, I only here music and everything if I will use headphone, when I'm going to use the loudspeaker there is nothing coming out..Need your help
    Android Enthusiast Skunk Fox's Avatar
    5 times
    I'm afraid this might be a hardware problem. You can't hear any sound drom the speaker at all? Did something happen since this problem occured? And how long is it so?
    Feb 2012
    Quote Originally Posted by Skunk Fox View Post
    I can't hear anything, I have updated my firmware, done hard reset but nothings happened
    Super Moderator cali's Avatar
    Sep 2011
    191 times
    Are you beyond the return period? If not, I would replace the device with one that works or otherwise take it in for repair/replacement.
    Android Lurker woodslink's Avatar
    Apr 2012
    2 times
    Wired Headphone Routing Fix
    There is an issue with a lot of Android devices where the OS thinks the headphone is being plugged in and unplugged on its own.
    I have rooted 4.0.4 AOKP and it still occured.
    Try this FREE application (no ads) to resolve it:
    https://play.google.com/store/apps/d...honeroutingfix
  1. Speaker switches on automatically. plz help
    By cruzer_rock in forum Samsung Galaxy Ace
    Last Post: 09-05-2011, 01:25 AM
  2. Speaker sucks !!
    By sketch42 in forum HTC Inspire 4G
    Last Post: 03-10-2011, 05:43 AM
  3. earpiece speaker
    By Bubba in forum LG Ally Help
    Last Post: 12-16-2010, 02:48 PM
  4. Very loud noise when turning Ally on.
    By Kt5 in forum LG Ally Help
    Last Post: 11-05-2010, 04:13 PM
  5. alarm clock sound is too loud & calendar didn't pop out
    By treasurewen in forum LG Ally Help
    Last Post: 09-07-2010, 11:21 PM
andriod no speaker sound
android ally ear speaker not working
android loud
android no loud
android no sound
android no speaker
android os speakers not working
loud speaker not working android tablet
noloud
