Skype Audio Issue
This is a discussion on Skype Audio Issue within the Android Audio forums, part of the Android Discussions category; Howdy, I just got my first Android about a week ago, and I have run into an issue with it. I am using the Motorolla ...
Thread: Skype Audio Issue
    Android Lurker Zaku77's Avatar
    May 2012
    Skype Audio Issue
    Howdy, I just got my first Android about a week ago, and I have run into an issue with it. I am using the Motorolla Droid Razr Maxx. Whenever I use it with Skype it makes this really bizarre popping/crackling noise. I can usually stop this by turning it down, but then it's really quite hard to hear. It seems like it's only using the earpiece, and not the media speaker on the back of the device. I do not notice this issue with any other audio. Ringtones, music, and videos all sound great at max volume. Any ideas of what I should do?
    Thanks!
    Android Lurker royfernandez's Avatar
    Apr 2012
    4 times
    Did you try the Skype Test Call feature? Do you hear those crackling sounds when it is played back?
    Are the calls noisy only on Skype or regular calls too?
    Android Lurker phudson126's Avatar
    Jun 2012
    I guess you should test the earpiece quality with some other device and then test the sound of Motorola Droid Razr Maxx in loud speaker. This will clearly indicate where the sound is coming from. Also try the Skype test call feature. If nothing works, try re-installing Skype and try again.
    Android Lurker marielcarino's Avatar
    Jun 2012
    Are you sure you have good internet connection? I had similar problems while using skype but had it fixed with a better connection.
    Sent from my GT-I9003 using Android.net
  1. Freeze Issue and Reboot Issue
    By clarkiboi in forum Android Forum
    Last Post: 03-18-2012, 10:37 PM
  2. Skype keeps cutting out
    By mjkohler in forum Android Forum
    Last Post: 01-31-2012, 01:16 PM
  3. Random issue. BIG ISSUE.
    By jgreenmusic in forum Beginning Developers
    Last Post: 09-21-2011, 10:11 AM
  4. Sprint issue or Droid issue?
    By geetarmikes in forum Sprint
    Last Post: 06-08-2011, 01:21 PM
android skype sound problem
android skype voice problem
clicking sound on skype
droid razr maxx skype cracking sound
how to solve skype audio problems in android
my android skype is voice problem
skype android crackling
skype android loud
skype android sound problem
skype android sound problems
skype audio clicking android
skype audio problems android
skype audio test android
skype crackling sound android
skype sound problem android
