The battery expiration is three years whether you use it or not. Don't let your battery fully drain off. That will speed up its wastage. You can charge it when 20% left. And don't over charge it while it is full charge.
Don't charge your battery while lower than 20% power, or higher than 80% power.Charge it while it's 40~60% battery power.
Hope that helps!
