Extended Battery or Standard Battery, Which One Do You Like?
This is a discussion on Extended Battery or Standard Battery, Which One Do You Like? within the Android Forum forums, part of the Android Discussions category; Are you confused when buying a replacement battery for your cell phone? Which kind of battery is good, extended battery or standard battery? In my ...
Thread: Extended Battery or Standard Battery, Which One Do You Like?
    Android Lurker PurpleGrape's Avatar
    Sep 2013
    Are you confused when buying a replacement battery for your cell phone? Which kind of battery is good, extended battery or standard battery? In my opinion, it depends on your need of this replacement battery.
    Some people think that standard battery is better than extended battery. They say that there are many risks when using extended battery. The high capacity may cause serious accidents. The extended battery which is large in size will disfirgue the cell phone. Extended battery means more capacity, but it also means more money and more risks. In fact, the risk of accidents usually results from the inferior batteries produced by illegal manufacturers. If the production technology and materials are good, how can extended batteries become bombs? Don’t you think so?
    I think that you can buy a standard battery if you usually use your cell phone lighhtly. Stock battery can fit the cell phone well, so that you needn’t pay for the added capacity and another
    back cover. It is more economical for you than buying an extended battery. If your cell phone is often thirsty for more juice, you’d better buy an extended battery because it can allow your cell phone to run longer. As well, it can remove the stress you feel when you forget your charger or power bank. If you are a lazy bone like me who is fed up with charging the cell phone everyday and hate carrying along a heavy power bank, to get an extended battery is also a good idea. What about your opinion?
  1. Extended Battery?
    By scottrod in forum LG Optimus Q L55c
    Last Post: 11-06-2012, 09:36 AM
  2. Replies: 3
  3. Extended Battery
    By KUJO in forum Motorola Droid 2 Global
    Last Post: 05-23-2011, 11:55 AM
  4. Replies: 3
    Last Post: 12-05-2010, 10:13 AM
  5. Replies: 2
    Last Post: 05-17-2010, 01:46 PM
is an extended life battery for android better than standard battery
