How to fix the bootloop on my PadFone?
This is a discussion on How to fix the bootloop on my PadFone? within the Android Forum forums, part of the Android Discussions category; Hi, Yesterday I've installed Antutu on my Asus The new Padfone Infinity A86, started it and from then it wont load. Here is detailed explanation ...
Thread: How to fix the bootloop on my PadFone?
    Android Lurker radibg2's Avatar
    Mar 2016
    Hi,
    Yesterday I've installed Antutu on my Asus The new Padfone Infinity A86, started it and from then it wont load. Here is detailed explanation of the prolem:
    The boot Asus logo shows, the other Asus logo shows then the ROM background(wallpaper) image shows and immediately restarts/my PC recognizes Padfone T004 MTP and immediately restarts. Here is what I have tried:
    1. Factory reset and cache wiping.
    2. Reinstall with firmware versions from 12.4.0.72 to 11.2.5.26, performing 1. for every of the versions(there are no custom ROMs for this device).
    3. Installed TWRP and tried 1 and 2 again.
    4. Formated the system, data, chache, dalvik cache and internal storage partitions.
    5. Tried 1 and 2 again(Figured out that 12.4.*.* versions are just updates and continued trying with 11.2.5.26).
    6. Removed the phone's battery for 10 minutes.
    7. Reinstalled boot.img and recovery.img trough fastboot.
    8. Created system.img from the system folder in firmware version 11.2.5.26 and installed boot.img, recovery.img and system.img trough fastboot.
    This problem occurred to me again a few months ago when I started Beach Buggy but cache wiping fixed the problem then, now I can't fix the problem. Do you have any idea how can I fix my PadFone?
    Super Moderator CR6's Avatar
    Idaho
    222 times
    Return you device to stock and then try downloading it. Run the app, uninstall Antutu (since this isn't an app that needs to be run more than once) and reroot your device. OR, download one of the other half dozen benchmark apps that work equally as well.
    Good luck!
    S5 tap'n
  1. Replies: 0
    Last Post: 12-11-2013, 12:23 PM
  2. Bootloop :(
    By Bkh1994 in forum HTC Droid Incredible
    Last Post: 10-29-2013, 09:06 PM
  3. Need Help! LG Mytouch Q is stuck in bootloop
    By mjc120671 in forum Rescue Squad Help
    Last Post: 02-15-2013, 04:24 AM
  4. Galaxy player 3.6...bootloop
    By orangemaniac in forum Rescue Squad Help
    Last Post: 11-05-2012, 11:33 PM
asus padfone 2 stuck at booting
fix padfone 7 boot loop
new padfone infinity boot loop
