Help - made dumb mistake on phone
This is a discussion on Help - made dumb mistake on phone within the Android Forum forums, part of the Android Discussions category; I made a stupid mistake on my phone, running android 2.1. I rooted the phone and was fooling around with it when I changed the ...
Thread: Help - made dumb mistake on phone
    Android Lurker David Stein's Avatar
    Angry Help - made dumb mistake on phone
    I made a stupid mistake on my phone, running android 2.1. I rooted the phone and was fooling around with it when I changed the LCD density (didn't do a backup, I know! very stupid). After a restart the icons are very big and when I try to change the LCD density back on the app I can't give the app Superuser access because the allow button on the touch screen is off the screen so I can't select. I did a factory reset but that didn't fix the issue. My phone has a pull out keyboard, anyway I can use it to select option on the screen? or anyone know a way around this???
    Thanks a lot!!!
    Super Moderator CJM's Avatar
    MS Gulf Coast
    51 times
    You might be able to use the directional pad to select the options. Though you can see them, it will be trail and error until you click the right one.
    Sent from my Droid using Android.net App
    d pad doesnt work
    hey, thanks for the reply, although D-pad on the key board doesn't do anything
    197 times
    FurryVarmint
    Can you boot into safe mode?
    not sure how to boot in safe mode, this phone hasn't been out for too long so not too many articles on it
    197 times
    FurryVarmint
    Try pulling the battery, waiting 30 seconds, then pressing and holding the search key on the keyboard while powering up. Worst-case scenario you have a regular bootup.
  1. System Dump from HTC Inspire 4G Made Available
    By wicked in forum Android News
    Last Post: 02-05-2011, 08:40 PM
  2. Switching Keyboards in Honeycomb made easy
    By tp76 in forum Android News from the Members
    Last Post: 02-04-2011, 05:59 AM
  3. I made it!!
    By maybish in forum Introductions & Site Assistance
    Last Post: 01-14-2011, 07:02 PM
  4. I finally made it...
    By mrdroid in forum Introductions & Site Assistance
    Last Post: 01-13-2011, 09:53 PM
  5. Epic Root made easy!
    Last Post: 08-05-2010, 10:29 AM
android lcd density reset
android mistake with lcd
android mistake with lcd density
help lcd density to big
help reset lcd density
how to reset lcd density android
how to root xt300
lcd density reset
lcd too big to allow superuser
motorola spice safe mode
reset density lcd android
reset lcd density
root motorola spice xt300
root motorola xt300
safety change lcd density
