Help
This is a discussion on Help within the Android Forum forums, part of the Android Discussions category; Hello, I am new to tablets and have only had mine a few weeks.I have erased all data or factory reset and am now stuck ...
Results 1 to 10 of 11
Thread: Help
    Android Lurker mpw1954's Avatar
    Help
    Hello, I am new to tablets and have only had mine a few weeks.I have erased all data or factory reset and am now stuck on a browser page.No wi fi,no settings nothing.If i plug in to pc can see all the android files.Can someone help.Mid 700 os 2.1 version 2.1.1.Was told cant upgrade or flash it.Thanks Michael
    Android Enthusiast RayBan's Avatar
    19 times
    i'm not familiar with the mid 700 ... how did you perform the factory data reset? as in, what steps did you go through?
    Hi Thanks for reply.I had tablet attatched to pc to by usb.Synching music and video,all was ok .Then I remember reading that a reset might sort out Android Market problems ie market cant see my tablet.So,stupidly i clicked the reset button ,I knew I would lose the few apps that I had managed to download but not end up with nothing.I appear to have a browser page that says Web page not available The web page at www.launcherpro.com might be down or moved etc.I cant get away from this page,home button takes me there,no wi fi icon,no dock or settings. If i plug tablet to pc i can see all my files,apps etc,one file has all apps backed up. Do I need to send all these files back to tablet or am I viewing what is still on there, and if so how do I open settings and home page.Sorry if i am talking nonsense,i am an idiot so far as techie things go.Michael.
    197 times
    FurryVarmint
    Can you get into the main settings?
    Hi No ,michael
    197 times
    FurryVarmint
    Can you reboot the device? You may have to pull the battery.
    Its a sealed unit.no external place to re boot or factory re set, what if i leave it on to drain the battery.
    197 times
    FurryVarmint
    It'll power off, then you can reboot it. It's slow, but it'll let you see if the problem persists after a reboot.
    Thankfully the battery on tablets is only good for a few hours of extended use..
    Thank you for advice, fingers crossed for a re boot,will let you know.Michael
    Hi It came back on on its own thank God.Wont be messing about with settings I dont understand anymore.Thanks for your help though,Michael.
android mid-700a
hard reset mid700
how to do factory reset on mid 700
mid 700 hard reset
mid-700a# android market
mid700 hard reset
mid700 reset
mid700 tablet upgrade
mid700a factory reset
mid700sc hard reset
reset mid 700 tablet
reset mid700
