forgot lock code
This is a discussion on forgot lock code within the Android Forum forums, part of the Android Discussions category; Hi anyone, i cant remember my unlock pattern on my mid pad can anyone help me, how do i reset it...
Thread: forgot lock code
    Android Lurker carolyn's Avatar
    forgot lock code
    197 times
    FurryVarmint
    Hi there, carolyn. Sorry to hear about your problem. The only way I can think to bypass/reset this problem is to do a factory reset, but that would cost you all the data on the device.
    Is this stock or a 3rd-party security? Also, what exactly is the device in question? Depending we might be able to offer you a different solution to get past it.
  1. Replies: 6
    Last Post: 02-22-2011, 02:50 AM
  2. Any Way To Put Widgets On Lock Screen?
    By DisneyRicky in forum Android Forum
    Last Post: 01-26-2011, 04:55 PM
  3. Can you lock the touchscreen while in TV or movie mode?
    Last Post: 01-13-2011, 07:08 PM
  4. HTC Desire HD Source Code Released
    Last Post: 10-25-2010, 01:55 PM
andriod forgot code
android forgot lock code
android lock codes
cant remember android lock code
forgot android lock code
forgot android lock screen code
forgot android playstore security code
forgot android unlock code
forgot lock code on android
forgot screen lock code android
how do i get my android screen lock.code
how to bypass lockscreen on lgl38c
how to unlock lgl38c android
i forgot android lock code
i forgot my security pattern on my polaroid tablet
