Weird battery
This is a discussion on Weird battery within the Android Forum forums, part of the Android Discussions category; I listen to music while I shower in the morning than I put my phone back on the charger for the day. Sometimes its still ...
Results 1 to 9 of 9
Thread: Weird battery
    Android Sr Member jon_l85's Avatar
    wisconsin
    Weird battery
    I listen to music while I shower in the morning than I put my phone back on the charger for the day. Sometimes its still at 100% and sometimes 88%. Why so diverse?
    Sent from my Ally using Android.net App
    197 times
    FurryVarmint
    Are you streaming music or listening to MP3s?
    Streaming will take more juice because of the WiFi/3G antenna getting hit so hard. Signal strength, length of shower, etc, will all have an impact, too.
    DO NOT WRITE IN THIS SPACE
    Android Enthusiast Paul Gyver's Avatar
    Long Beach, CA
    6 times
    Where can I get a waterproof case for my phone?
    What's a Bieber?
    wisconsin
    I use mp3. I usually take the same amt of time in the shower.
    197 times
    FurryVarmint
    Do you leave your phone on the charger all night, every night?
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    Have you tried a battery calibration? When percentages vary that much with the same type of usage, then its usually one of these two things:
    1.) Your battery is reaching the end of its charge/discharge cycle life or...
    2.) Your battery calibration stats are screwed up.
    Android Enthusiast RayBan's Avatar
    19 times
    Quote Originally Posted by Dorian View Post
    +1 batteries do have a life cycle and start to lose their capacitance after awhile, but it could just be the "battery stats" which a log file contained in your system that helps to determine the battery % based on historical values. If your battery never makes it low on the scale because of being on the charger too often (for instance if the cycle length was from 100%-30%), it can cause issues with your calibration -- meaning the battery "thinks" it has less battery than it actually does.
    If the battery is reaching the end of its life cycle, a new one is in order.
    Conversely, if it's just a calibration issue, deleting the battery stats log file is easy if you are rooted.
    Sent from my Droid using Android.net App
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    Quote Originally Posted by vuarnet View Post
    Before you do delete them though, charge it to 100%. Then while still on the charger, delete the stats file then turn completely off then back on. Now don't place it back on charge till it literally turns itself off from low battery. Then charge back to 100%.
    With that done, you've reset your battery stats AND given it an initial calibration.
    19 times
    +1 this is the procedure you want to follow to calibrate your battery meter, but (since I wasn't sure if you were rooted or not) I didn't want to give you a procedure you couldn't complete. To sum up (if you're rooted):
    - charge to 100%
    - delete battery stats log file
    - charge back to 100%
    - let phone die until it cuts off (do not charge or reboot, including connecting via USB)
    - re-charge to 100%
    - DONE!
    If you're not rooted, however, I don't believe there is a way to do this since the log file is in the R/O memory.
  1. Weird/Funny Emoticon/Smiley/Smilie Thread
    By furbearingmammal in forum Off-Topic Forum
    Last Post: 04-05-2011, 02:05 AM
  2. Just to prove I'm either totally weird or completely insane...
    Last Post: 03-10-2011, 07:01 PM
  3. Battery
    Last Post: 02-04-2011, 04:17 AM
  4. Buy a Second battery
    Last Post: 12-02-2010, 07:44 PM
android battery log
android battery log file
android not charging to 100%
battery log file android
can the battery log file be deleted ?
clear battery log android
datpiff app
delete android battery log
delete battery log android
how to clear battery log android
how to fix delete battery logs not charging to 100 android
lg ally battery calibration
lg ally battery recalibration
lg ally recalaberation for battery
og droid not charging
