Battery temperature
This is a discussion on Battery temperature within the Android Forum forums, part of the Android Discussions category; Just wondering what kind of temps are safe? Usually mine is always below 100 but yesterday I got it to 107 after some moderate use. ...
Thread: Battery temperature
    Android Enthusiast Paul Gyver's Avatar
    Long Beach, CA
    6 times
    Battery temperature
    Just wondering what kind of temps are safe? Usually mine is always below 100 but yesterday I got it to 107 after some moderate use. I'm running PE 5.0.2 with stock kernel. At what point is meltdown?
    Sent from my Droid using Android.net App
    What's a Bieber?
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    I'm guessing you're talking Fahrenheit... because Celsius would be burning your face..lol
    Under to right under 100F is normal, and a bit over 100F is normal while talking on it or while charging. If it goes above 110-115F though, I think it will automatically stop charging so it can cool back down.
    El Paso, TX
    59 times
    _B0BB0_
    The phone will go to cool down mode at about 120 degrees F. Found that out on the X doing a lot of downloading overclocker to 1480mhz. Dumb mistake cuz I had max and min set at 1480 and forgot to reset it. No damage though
    Android Lurker androidrobot's Avatar
    Tablet PCS temperature is battery usually higher !but also need to be careful
    197 times
    FurryVarmint
    I don't think the Droid 1 has much of a thermal protective circuit without a temperature monitor running.
    DO NOT WRITE IN THIS SPACE
    Somewhere on Kamino
    83 times
    Not too sure on original droid and yes most specs say 120 F.
  1. Extended Battery
    By Blueduck3285 in forum Motorola Droid X
    Last Post: 04-10-2011, 09:44 PM
  2. Battery Question
    By jon_l85 in forum LG Ally
    Last Post: 03-10-2011, 10:44 PM
  3. Battery
    Last Post: 02-04-2011, 04:17 AM
  4. Training battery
    By Kendrickroad in forum Android Forum
    Last Post: 01-29-2011, 12:33 AM
  5. Buy a Second battery
    Last Post: 12-02-2010, 07:44 PM
android battery temperature
android battery temperature range
how to check battery temp on android
normal battery temperature
normal battery temperature android
normal battery temperature of android mobiles
normal temperature for android phone
normal temperature of android phones
normal temperature of phone
safe battery temperature
safe tablet temp
tablet battery temp
what is a good battery temperature for android
what is normal battery temperature android phone
what is the normal temperature of a phone battery
