Is Froyo2.2 requires 64 bit build environment?
This is a discussion on Is Froyo2.2 requires 64 bit build environment? within the Android Forum forums, part of the Android Discussions category; Hi there, very good to you all, i jus paused while building the Froyo 2.2 version in my Virtual Box, because it cause some compilation ...
Thread: Is Froyo2.2 requires 64 bit build environment?
    Android Lurker viki's Avatar
    Apr 2011
    Hi there,
    i jus paused while building the Froyo 2.2 version in my Virtual Box, because it cause some compilation error. I knew from some forums, Froyo 2.2 requires 64 bit build environment. Here i could listed the sufficient data about my environment setups.
    OS: Fedora Core 12
    build environment(PC): 32 bit architecture
    Android Version: Froyo 2.2
    Apologies for my english
    Android Lurker Eagle1967's Avatar
    Apr 2011
    Colorado
    droid1967
    not froyo
    Quote Originally Posted by viki View Post
    Hi there,
    OS: Fedora Core 12
    Hi froyo does not require a 64 bit build environment it can be built on 32 bit. gingerbread source requires 64bit but cm has a commit to make it build on 32bit also.
  1. Replies: 0
    Last Post: 03-16-2011, 04:48 PM
  2. Samsung Captivate KB1 Froyo build for AT&T leaked [Video]
    By wicked in forum Samsung Captivate
    Last Post: 02-23-2011, 02:46 PM
  3. Replies: 4
    Last Post: 02-09-2011, 02:04 PM
  4. Android does .... Build websites .... Everything
    By probbiethe1 in forum Off-Topic Forum
    Last Post: 01-18-2011, 04:10 PM
  5. Logitech Revue Rooted - Requires Hardware Mod
    Last Post: 01-05-2011, 11:54 AM
android 64bit build
android architecture 64 ou 32
android build 64 bit
android build 64-bit
android for pc 32 bit
android froyo build environment
android gingerbread build 32-bit
build android 64 bit
build android 64bit
does android require 64 bit os to build
froyo2.2
gingerbread 64 bit
gingerbread 64bit
is gingerbread 32 bit or 64 bit
only 64-bit build environments are supported beyond froyo/2.2.
