video, battery indicator...
This is a discussion on video, battery indicator... within the Android Forum forums, part of the Android Discussions category; No there's no need to wipe the memory. That probably isn't the source of your battery issue though. Could be but I doubt it....
Results 11 to 20 of 28
Thread: video, battery indicator...
    El Paso, TX
    59 times
    _B0BB0_
    Android Lurker MrAsian's Avatar
    alright then. let me download circle battery widget and see how things go. thanks a lot
    El Paso, TX
    59 times
    _B0BB0_
    No problem. Let me know how things go.
    my video issue again. still laggy though. and i was being told that 800mhz processor shouldnt have any big issues when playing video. however, even a video with file size 6mb, it is also laggy.
    i was advised that it could be background apps, so should kill them. also, i was advised to do a factory reset instead as wel
    your opinion guys?
    Somewhere on Kamino
    83 times
    Factory data reset is an option. What videos are you trying to watch? Do not kill your background apps. Is it youtube videos?
    El Paso, TX
    59 times
    _B0BB0_
    If you're watching or trying to stream HQ vids over 3g it won't work. You need 4g or wifi
    Quote Originally Posted by Droid-Xer View Post
    Morning (my local time) friends.
    Surprisingly, I have no problems watching Youtube videos.
    However, I downloaded videos onto my laptop, and I transfer over to my samsung galaxy ace. I tried to play these videos on my phone, but it lags.
    And hmm, I heard there is a default video player in my phone itself, but I don't seem to find it ?
    Somewhere on Kamino
    83 times
    Ok what is the file extension for the videos? How large are the videos? Are they sized for mobile?
    El Paso, TX
    59 times
    _B0BB0_
    Ah ok. Its not as easy as that to drag and drop movies. You need to convert them. I use DVD Catalyst. It's $9.99 but converts any movie to my android devices.
    currently I am using flv. used avi, mpeg-4, mkv before as well. All laggy
    for now, only those video file size below 6mb won't lag. 6mb and above will lag. The larger the video file size, the laggier it goes. Only the video lag, the sound doesn't lag.
    Any other FOC converter ?
  1. Replies: 3
  2. Battery temperature
    By Paul Gyver in forum Android Forum
    Last Post: 03-24-2011, 12:47 AM
  3. Replies: 2
    Last Post: 02-16-2011, 01:43 AM
  4. Battery
    Last Post: 02-04-2011, 03:17 AM
  5. Buy a Second battery
    Last Post: 12-02-2010, 06:44 PM
android battery indicator doesnt move
battery gauge for samsung galaxy ace
battery meter samsung galaxy ace
galaxy ace battery indicator
galaxy s 3 vidio battery indicator
galaxy tab battery meter reset
how to change my samsung ace battery bar
how to change the galaxy ace battery indicator
samsung galaxy ace battery indicator
samsung galaxy ace battery meter
samsung galaxy ace indicator icons
samsung galaxy s2 battery indicator
samsung galaxy tab battery indicator
understanding the battery meter for samsung galaxy ace
where is the battery indicator in galaxy ace
