video, battery indicator...
This is a discussion on video, battery indicator... within the Android Forum forums, part of the Android Discussions category; There are a lot....
Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: video, battery indicator...
  1. #21
    Somewhere on Kamino
    83 times
    There are a lot.
  2. #22
    Android Lurker MrAsian's Avatar
    There are a lot.
    hi. you mean ? the video file size too big, or i used too many formats ?
  3. #23
    Somewhere on Kamino
    83 times
    Oh I meant there are a lot of conversion software programs. Your files are too large. Need to convert for mobile and I would keep the size under 5mb
  4. #24
    i tried to convert but the video quality drops though. hmm, i guess this is unevitable ?
  5. #25
    Somewhere on Kamino
    83 times
    Use the one Droid xer suggested. It works and video quality has no loss.
  6. #26
    thank you. i will be back should i encounter any more problems
  7. #27
    it seems that if my video fps is over 15fps, it lags. so for now, i managed to reduce my video fps to 15fps and below, no more lags, though video quality dropped a little.
    now comes this part -- there are so many video format, which should i choose ? flv, avi, mpeg-4 ?
    for now i chosen flv. bit rate 781 kbps, 15fps, 640 x 480. good enough i suppose ?
  8. #28
    Somewhere on Kamino
    83 times
    It's up to you if you think it's good enough. Remember though that your taking a recorded video that was converted by someone and it's placed on the internet, then your downloading it and converting it again to match your phone screen size, fps, and processor speed. Therefore you lose quality. So, if you want better quality convert your own DVDs that way your eliminating some of the reduction in quality. As far as format see what plays best on your phone.
  1. Replies: 3
    Last Post: 07-09-2011, 06:57 PM
  2. Battery temperature
    By Paul Gyver in forum Android Forum
    Last Post: 03-24-2011, 01:47 AM
  3. Replies: 2
    Last Post: 02-16-2011, 02:43 AM
  4. Battery
    Last Post: 02-04-2011, 04:17 AM
  5. Buy a Second battery
    Last Post: 12-02-2010, 07:44 PM
android battery indicator doesnt move
battery gauge for samsung galaxy ace
battery meter samsung galaxy ace
galaxy ace battery indicator
galaxy s 3 vidio battery indicator
galaxy tab battery meter reset
how to change my samsung ace battery bar
how to change the galaxy ace battery indicator
samsung galaxy ace battery indicator
samsung galaxy ace battery meter
samsung galaxy ace indicator icons
samsung galaxy s2 battery indicator
samsung galaxy tab battery indicator
understanding the battery meter for samsung galaxy ace
where is the battery indicator in galaxy ace
