video, battery indicator...
This is a discussion on video, battery indicator... within the Android Forum forums, part of the Android Discussions category; it seems that i have some problems ? my video is very laggy, and my battery indicator seems malfunctioning (i dont see the bar move, ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: video, battery indicator...
    Android Lurker MrAsian's Avatar
    it seems that i have some problems ? my video is very laggy, and my battery indicator seems malfunctioning (i dont see the bar move, but when i restart, i see my bar decreased quite an amount)...?
    i tried to use moboplayer, qqplayer, rockplayer, but video played is laggy. my processor too weak ?
    Somewhere on Kamino
    83 times
    You using stock or custom rom? What phone? Is it rooted?
    samsung galaxy ace. not rooted.
    Somewhere on Kamino
    83 times
    Send it back.
    Sent from my T-959
    El Paso, TX
    59 times
    _B0BB0_
    Are you trying to play videos online or from the memory card? You're not using any task killers are you?
    i not using any task killer.
    my batt indicator bar doesn't move at all, unless i restart my phone
    El Paso, TX
    59 times
    _B0BB0_
    I use a widget called "circle battery widget" to give me an accurate reading.
    circle battery widget ? to check for batt status ? let me try it out.
    do you think it is because i go clear memory at my RAM management, hence the batt indicator cannot give me an accurate reading at all ?
    thanks
    El Paso, TX
    59 times
    _B0BB0_
    What do you mean you clear your ram? So you are using a task killer??
    task manager > RAM > RAM Management > Clear Memory
    this is task killer ? i shouldn't do it ?
  1. Replies: 3
  2. Battery temperature
    By Paul Gyver in forum Android Forum
    Last Post: 03-24-2011, 12:47 AM
  3. Replies: 2
    Last Post: 02-16-2011, 01:43 AM
  4. Battery
    Last Post: 02-04-2011, 03:17 AM
  5. Buy a Second battery
    Last Post: 12-02-2010, 06:44 PM
android battery indicator doesnt move
battery gauge for samsung galaxy ace
battery meter samsung galaxy ace
galaxy ace battery indicator
galaxy s 3 vidio battery indicator
galaxy tab battery meter reset
how to change my samsung ace battery bar
how to change the galaxy ace battery indicator
samsung galaxy ace battery indicator
samsung galaxy ace battery meter
samsung galaxy ace indicator icons
samsung galaxy s2 battery indicator
samsung galaxy tab battery indicator
understanding the battery meter for samsung galaxy ace
where is the battery indicator in galaxy ace
