Possible solution to Droid X spontaneous reboot.
This is a discussion on Possible solution to Droid X spontaneous reboot. within the Android Forum forums, part of the Android Discussions category; I went burrowing into the Motorola and a whole slew of other Droid forums, and communities. I ran across one person who says he cured ...
Thread: Possible solution to Droid X spontaneous reboot.
    Android Lurker David Albert Desrosiers's Avatar
    Phoenix, AZ.
    I went burrowing into the Motorola and a whole slew of other Droid forums, and communities. I ran across one person who says he cured the issue by reformatting the SD card. This user swears that since he has done this, all spontaneoud rebooting has ceased. I'm trying the method myself. So far, zero reboots. I'll report continued success, or if the solution fails.
    Android Lurker David Desrosiers's Avatar
    After one reboot, I tried reformatting the SD card using my PC, not the phone. All good so far.
    Phoenix, AZ.
    Never mind.
    No joy with the SD card format curing reboot disorder. Back to the drawing board.
    El Paso, TX
    59 times
    _B0BB0_
    There are so many variables that call random reboots. Could be 2 apps don't play well together, could be a corrupt file on sd (which format would fix), system errors, custom rom, having too many apps
    Phoenix, AZ.
    No pattern
    There's just no clear pattern or common thread to the issue. It seems to strike on bone stock phones, rooted ones with a truckload of apps, auto rotate turned on, off, you name it.
  1. Spontaneous shutdown.
    By David Albert Desrosiers in forum Android Forum
    Last Post: 05-19-2011, 12:48 AM
  2. Replies: 18
    Last Post: 05-02-2011, 09:35 AM
  3. Replies: 0
    Last Post: 03-15-2011, 10:44 AM
  4. Replies: 2
    Last Post: 02-08-2011, 04:16 PM
android spontaneous reboot
droid restarts itself
droid x reboot
droid x rebooting
droid x reboots
droid x reboots itself
droid x restarts itself
droid x spontaneous reboot
droid x spontaneously restarts
droid x2 rebooting
droid x2 rebooting itself
droid x2 reboots
droid x2 reboots itself
droid x2 restarts
droid x2 restarts itself
