Wifi keeps automagically starting
This is a discussion on Wifi keeps automagically starting within the Android Forum forums, part of the Android Discussions category; Hi Forum Been looking around, but I havn't spotted anyone who's reported similar happenings.... I can run my phone for days without problem, then I'll ...
Thread: Wifi keeps automagically starting
    Android Lurker carlbeech's Avatar
    Hi Forum
    I can run my phone for days without problem, then I'll play a game (Air Control), then, even though I've turned my wifi off, it keeps restarting by itself. Its annoying - a) it's draining my battery, and b) my phone plays a sound when an email arrives, which wakes me up in the middle of the night!
    While I'm going to de-install Air Control, I'm beginning to wonder if it's because the program uses 'AdMob' advertising - as I'm sure I've done the same before, and I've played a different game, which uses AdMob, and it's had the same effect...
    I'm running 'CyanogenMod 6' - (i.e. Froyo) on a Hero GSM.
    Has anyone else seen this problem - and does it appear to be linked to AdMob?
    Cheers
    Carl.
    El Paso, TX
    59 times
    _B0BB0_
    Yes the game might have permission to turn the WiFi on so that it can keep its ad database up to date. Are you rooted?
    197 times
    FurryVarmint
    Sounds like it might be a glitch. Check the game to see if it has network/WiFi access. If so it's probably turning it on.
    DO NOT WRITE IN THIS SPACE
    Somewhere on Kamino
    83 times
    Ok as far as air control game by developer four pixels is concerned it requires full internet. It shouldn't be causing your phone to turn on wifi. What it sounds like to me is your phone is using sync for your Google account. Go to settings and then account and sync. Turn off your sync and you shouldn't get email notification. If it still turns on your wifi then uncheck background data in accounts and sync when your going to bed. It's a little bit of a hassle but will stop the irritation of battery drainage and annoying emails in middle of the night.
    Quote Originally Posted by Droid-Xer View Post
    Yep - I'm rooted, and I'm running cyanogenmod 6 - is there something I can run as root?
    Cheers
    Carl
    197 times
    FurryVarmint
    Try installing AdFree from the Market. Not that we're encouraging preventing the developer from getting paid by said ads, but if it stops the WiFi from engaging automatically then we'll have figured out the issue.
    Here's a link. https://market.android.com/details?i...=search_result
  1. Replies: 2
    Last Post: 05-30-2011, 07:01 PM
  2. Google I/O 2011 Starting Today
    By dgstorm in forum Android News
    Last Post: 05-10-2011, 11:37 AM
  3. Replies: 0
    Last Post: 03-01-2011, 01:07 PM
  4. Reviews Are Starting to Arrive
    By scrounger in forum Motorola Atrix
    Last Post: 02-10-2011, 09:21 AM
  5. Epic 4G Pre-Orders starting tomorrow?
    Last Post: 08-06-2010, 09:52 PM
android keeps turning wifi on
android wifi keeps resetting
android wifi starting by itself
cyanogen wifi turns itself on
cyanogenmod wifi keeps turning on
epic 4g wifi keeps turning on
motorola atrix wifi keeps turning off
motorola atrix wifi keeps turning on
samsung epic wifi keeps turning on
samsung epic wifi turns on by itself
why does my epic keep turning on wifi
why does my motorola atrix keep restarting
why does my motorola atrix keep turning off
why does my wifi keep turning on android
wifi keeps turning on android
