Anything worth doing following firmware upgrade?
This is a discussion on Anything worth doing following firmware upgrade? within the Android Forum forums, part of the Android Discussions category; Just want to get peoples opinions on this... I had trouble upgrading to 2.3 Gingerbread from 2.2 Froyo, which was ultimately resolved by doing a ...
Thread: Anything worth doing following firmware upgrade?
    Android Lurker MAWglobal's Avatar
    Jun 2011
    Question Anything worth doing following firmware upgrade?
    I had trouble upgrading to 2.3 Gingerbread from 2.2 Froyo, which was ultimately resolved by doing a (software) reset at which point Kies recognised an upgrade was possible. It also seemed to fix something where the newest Kies couldn't access my phonebook- after the upgrade that worked fine.
    So- is there any benefit in doing a system reset every once in a while? Backing up your numbers, clearing everything out and then reloading everything?
    On the one hand it's going a bit Windows 98, but on the other if it helps things worksmoothly who am I to argue?!
    190 times
    FurryVarmint
    You shouldn't have to unless something screws up.
    Also, consider trying ODIN instead of Kies. Kies has some issues.
    DO NOT WRITE IN THIS SPACE
    Somewhere on Kamino
    67 times
    Exactly what Fbm said. You shouldn't have to and Odin works a lot smoother than kies.
    El Paso, TX
    56 times
    _B0BB0_
    No need for a reset. Maybe a reboot every now and then.
  1. upgrade problems
    By Eldin Honingh in forum Samsung Galaxy S
    Last Post: 06-08-2011, 02:30 PM
  2. Replies: 6
    Last Post: 06-01-2011, 10:23 AM
  3. Replies: 1
    Last Post: 05-22-2011, 01:39 PM
  4. Best SDHC card upgrade?
    By Oreo in forum Motorola Droid X
    Last Post: 04-04-2011, 01:26 PM
  5. G2 $49.99 New & Upgrade (Amazon.com)
    Last Post: 11-25-2010, 05:39 PM
silverlight android
worth updating to gingerbread?
