Help!!!
This is a discussion on Help!!! within the Android Forum forums, part of the Android Discussions category; Stupid question... Lets say I flashed, rooted, and put a custom rom on my Bell Motorola Atrix. Does that mean I'm not going to be ...
Thread: Help!!!
    Android Lurker SynysterCarm's Avatar
    Jun 2011
    Help!!!
    Stupid question... Lets say I flashed, rooted, and put a custom rom on my Bell Motorola Atrix. Does that mean I'm not going to be able update it come time bell finally releases a update for it?
    El Paso, TX
    59 times
    _B0BB0_
    Yes. You will need to be on the stock firmware. Did you make a backup of your stock setup?
    197 times
    FurryVarmint
    Assuming OTAs weren't blocked by the ROM, your phone will download it, run a CRC/hash check, fail, and probably report back to Bell that your phone failed to update.
    DO NOT WRITE IN THIS SPACE
    Metro Atlanta
    53 times
    That's a pretty big IF, considering the bootloader status of the Atrix. True custom ROMs do not exist for that device.
custom rom atrix bell
