Help X.x
This is a discussion on Help X.x within the Android Forum forums, part of the Android Discussions category; i did the same,, now i have those errors !! bright & wife.. AYUDA! ='( ... alguien sabe del ROM para latinoamerica (Ecuador-CLARO) ... ? ...
Results 11 to 12 of 12
Thread: Help X.x
    Android Lurker jKingEC's Avatar
    help
    i did the same,, now i have those errors !! bright & wife.. AYUDA! ='( ... alguien sabe del ROM para latinoamerica (Ecuador-CLARO) ... ? o alguna otra solucion para mi FIT ???
    197 times
    FurryVarmint
    English only, please.
    Google Translate This site may help you make yourself better understood, or to understand my response better.
    I do not know as there is a ROM for your phone at present. If you would like I can look for you, but I cannot guarantee that I will have any better luck than you have.
    DO NOT WRITE IN THIS SPACE
android forums
firwares s5670l
hard reset s5670b
hard reset s5670l
reseteo de samsung galaxy s5670b
rom s5670 latinoamerica
rom s5670 latinoametica
s5670b claro
s5670b hard reset
s5670b master reset
s5670l custom
s5670l factory rom
s5670l firmware
s5670l rom
s5670l stock rom
