Help X.x
This is a discussion on Help X.x within the Android Forum forums, part of the Android Discussions category; Hi the other day i flash my phone to gingerbread (galaxy fit s5670l), now the brightness change to 0 randomly, i flash to froyo but ...
Results 1 to 10 of 12
Thread: Help X.x
    Android Lurker PinG's Avatar
    Jun 2011
    Help X.x
    Hi
    the other day i flash my phone to gingerbread (galaxy fit s5670l), now the brightness change to 0 randomly, i flash to froyo but the problem dont go.
    i flash with the europe firmware.
    sorry for my english. xd
    197 times
    FurryVarmint
    Did you flash back to the stock firmware? If so, try reflashing and then do a factory reset before allowing it to boot. It might fix the problem.
    DO NOT WRITE IN THIS SPACE
    Jun 2011
    yes i flash the stock froyo 2.2 from samfirm, and i do the wipe and the reset factory and dont fix it. some times the brightness go up.
    where can i found the stock for america?
    and there's a difference between s5670L and s5670?
    Somewhere on Kamino
    83 times
    What software are you using for flash? If your using kies that may be the issue. Odin is by far one of the best when it comes to flashing a Samsung.
    Jun 2011
    i use odin. now i am having problems with the wifi too, =/ aaaaaaaaaaaa!! dx.
    wha is the more stable roms of froyo?
    197 times
    FurryVarmint
    If there's a CyanogenMod 7 version for your phone, try that. Just make sure you flash the app pack, too.
    Jun 2011
    no, cyangenmod is not compatible with this phone.
    there is a custom rom for this phone? or the rom for the GT-S5670L, i guess that the L is by Latinoamerica, so i need the rom for latinoamerica =/.
    can be this my problem? that i flash my phone with the s5670 europe rom.
    197 times
    FurryVarmint
    EXCLUSIVE GALAXY FIT - www.SamFirmware.com Not sure what to do with the information, but here you go.
    Jun 2011
    thanks, but was this page where I download the firmware from the beginning. Might be a problem with the dimming? any idea about this?
    might be a problem with the dimming? any idea about this?
    197 times
    FurryVarmint
    So you're already running that leak/update? Okay, then I'm at a loss. I'd say return the phone but since you rooted it you violated the warranty.
android forums
firwares s5670l
hard reset s5670b
hard reset s5670l
reseteo de samsung galaxy s5670b
rom s5670 latinoamerica
rom s5670 latinoametica
s5670b claro
s5670b hard reset
s5670b master reset
s5670l custom
s5670l factory rom
s5670l firmware
s5670l rom
s5670l stock rom
