Help - Samsung Galaxy Pro - Call quality & GPS issues
This is a discussion on Help - Samsung Galaxy Pro - Call quality & GPS issues within the Android Forum forums, part of the Android Discussions category; Dear All, I have recently bought a new Samsung Galaxy Pro (B7510) with Android OS 2.2.2 (Build DDKC4). Samsung Galaxy Pro B7510 - Full phone ...
Thread: Help - Samsung Galaxy Pro - Call quality & GPS issues
    Android Lurker inopro's Avatar
    Dear All,
    Samsung Galaxy Pro B7510 - Full phone specifications
    I am pretty happy with the phone barring two issues, which are:
    1) When I make or receive voice calls I hear voice spikes from time to time during the call duration. It does not happen for all calls, instead it is unpredictable. I am not sure of the cause. When I looked on the Samsung webpage for any possible tests/fixes, the webpage asked to run a diagnostic test using the following code *#0*# and then choosing reception melody. It said while the reception melody is playing and if I hear any interruption or disturbance of any kind then the device is faulty. But on running this test the phone passed it flawlessly.
    Now I am not sure what could the problem. Is anybody else experiencing this on their Galaxy Pro (B7510) or any other Android phone? Please help me with this issue as it is really annoying.
    2) my phone's GPS takes a lot of time to find & connect to the GPS satellites . Is this normal? How long should it take to find & connect on all Android based phone? Is there a way to improve connection speed? Please help...
    Thanking you in advance......
  1. Installation Issues on Samsung Galaxy S 2
    By DaWgY in forum Android Games
    Last Post: 07-21-2011, 01:01 PM
  2. Poor voice quality of SAMSUNG GALAXY ACE
    By ynaveeny in forum Samsung Galaxy Ace
    Last Post: 07-12-2011, 11:25 AM
  3. Replies: 0
    Last Post: 06-29-2011, 01:31 PM
  4. Replies: 0
    Last Post: 03-24-2011, 11:06 AM
b7510 call quality
call quality of galaxy ace
galaxy pro for nimbuzz call
how to activate gps on samsung galaxy ace
how to locate gps in samsung galaxy pro
how to use gps in samsung b7510
how to use gps in samsung galaxy pro
how to use gps on galaxy pro
how to use gps on samsung galaxy pro
samsung galaxy ace call quality
samsung galaxy ace voice quality
samsung galaxy pro call quality
samsung galaxy pro defects
samsung galaxy pro gps
samsung galaxy pro problems
