How low is too low?
This is a discussion on How low is too low? within the Android Forum forums, part of the Android Discussions category; How low of internal memory (mbs) would one start to notice problems (and I know apps will close as needed- to a point I would ...
Thread: How low is too low?
    Columbia, Misery (Missouri)
    8 times
    How low is too low?
    How low of internal memory (mbs) would one start to notice problems (and I know apps will close as needed- to a point I would assume)? 50? 20? 5? I know the variables are infinite. Is there a number?
    197 times
    FurryVarmint
    Internal storage? Shouldn't notice much of a problem until it's full -- but you'll start getting warnings below 15%, usually. Just need to clear some stuff out, move stuff to the SD card.
    DO NOT WRITE IN THIS SPACE
    8 times
    Okay. I had 56 or so (40%) before app cache cleaner and history eraser, almost 80 now (please see my post reply to Slag It! reply to "must have apps")(where I learned about cleaner and eraser)(can you find that easily?) As far as my sd card (back to original question) I'm hesitant because: please see question I posted yesterday ("Duplicates"). I don't want to lose any of my power-amp library. In another previous question, awhile back, I asked something to the effect of "how full can I let my 2gig card get before permissions from downloading new apps jeopardize my music files (and contacts and whatever else is vital)(delete/ modify sd card)? I don't know who's more confused now, but if there is a new question in this post I thank-you for your answer, albeit I hope I didn't do any cross-posting or anything. Everything seemed related somehow. Thank-you.
    Edit: I don't know where the faces are coming from. They're supposed to be the other half of parenthesis (no this isn't another question. You've enough on your plate of me already). Phew. I need a beer.
