HELP!!! How to Move files to external sd
This is a discussion on HELP!!! How to Move files to external sd within the Android Forum forums, part of the Android Discussions category; I plugged an external micro sd into my Samsung Galaxy S II but I don't know How to move my apps and games to my ...
Thread: HELP!!! How to Move files to external sd
    Android Lurker SoundStorm's Avatar
    Sep 2011
    I plugged an external micro sd into my Samsung Galaxy S II but I don't know How to move my apps and games to my external sd card. Any apps or any steps should I do to move them to the micro sd card?
    My SGS II version is 2.3.3
    Android Lurker pclum's Avatar
    Sep 2011
    I think there is a application call "App 2 SD (move app to SD)" in the android market may suit your need
    Android Lurker helios's Avatar
    Oct 2011
    Maybe this'll help? I have a Motorola Atrix dual core that came with a 16GB internal memory card storage to which I was able to add another 16GB micro sdcard as an extension. When I go into Settings >Applications on my phone it has the option to move to sdcard for most apps, some won't allow you to do it. As for moving files to sdcard you need to do that through your computer via your USB cable. With my phone I then go to my status bar where my options have opened up & I choose USB storage & then press OK. Next on your computer screen you should see 1 or 2 windows one behind the other. Click on the folder icon & your sdcards should open up & you'll be able to manage your files from there. I've created new folders on my sdcard-ext & named them, just as you would on your computer. Be a bit careful though I've moved music files from one card to another & at the time my music player couldn't find them anymore. Apps pretty much have to stay on your internal memory card. I use the external one for photos /pictures, movies /videos, audiobooks, & music which take up a lot of space. I've often had to restore everything. You have to learn by trial & error. Lots of panic & stress but its usually fixable. I've done 100's of factory resets & unmounted my sdcards to start over.
    Lots of good luck, hope I was of some help.
    Sent from my MB860 using Android.net
  1. Replies: 4
    Last Post: 03-22-2012, 09:06 AM
  2. login to external site? (Android)
    By jacko92 in forum Beginning Developers
    Last Post: 08-09-2011, 09:53 PM
  3. Replies: 1
    Last Post: 05-14-2011, 10:11 AM
  4. Replies: 1
    Last Post: 09-17-2010, 01:26 PM
android move files to external sd
android move to external sd
galaxy s2 move music to sd card
galaxy s2 move pictures to sd card
how to move files to external sd android
how to move gallery to micro sd card on samsung exhibit 2
how to move music to sd card on galaxy s2
how to transfer files to sd card on galaxy s2
how to transfer photos from gallery tk sd card on samsung galaxy s2
how to transfer photos to external storage on galaxy s2
how to transfer pictures to sd card on motorola atrix
move files to external sd card android
move music to sd card galaxy s2
saving downloaded music onto external sd card galaxy s2 at&t
