Running applications problem
This is a discussion on Running applications problem within the Android Forum forums, part of the Android Discussions category; So when I try to close down applications, sometimes they won't close and some will close but will start up again. How do I fix ...
Like Tree1Likes
  • 1 Post By Av6JL
Thread: Running applications problem
    Android Lurker Av6JL's Avatar
    Sep 2011
    So when I try to close down applications, sometimes they won't close and some will close but will start up again. How do I fix this problem?
    Columbia, Misery (Missouri)
    8 times
    Quote Originally Posted by Av6JL View Post
    You can't stop it, so don't waste your time with task killers or anything. Rooting can delete some of these apps. But your phone can easily manage those running apps so don't even worry about them.
    Sent from my LG-P509 using Android.net
    Sep 2011
    Ok. So these apps I can't close still draining my battery?
    8 times
    Very little.
    Administrator wicked's Avatar
    San Jose CA.
    259 times
    wwickedd
    No need to close them. Android keeps them in the background but doesn't really use up battery. Task killers are not needed on Android.
    Sep 2011
    Ok thanks for the help
    wicked likes this.
  1. Galaxy S2 Running HOT
    By etcromb in forum Samsung Galaxy S2
    Last Post: 10-04-2012, 12:52 AM
  2. Replies: 0
    Last Post: 09-07-2011, 04:58 AM
  3. Running v6 supercharged
    By Liquidvortex in forum LG Vortex
    Last Post: 08-08-2011, 12:49 PM
  4. Xperia Play Running With The FCC
    By WenWM in forum Android News
    Last Post: 04-03-2011, 09:53 PM
  5. Running Services
    By GrahamF in forum Android Forum
    Last Post: 03-14-2011, 04:31 AM
how to close running apps on background android
how to fix running apps in the background android
problems with droid running apps
