over heat
This is a discussion on over heat within the Android Forum forums, part of the Android Discussions category; Hi guys I have galaxy S2 ,It is almost OK except the heat that it produces epically when I play HD games or I use ...
Thread: over heat
    Android Lurker XeeR's Avatar
    Oct 2011
    over heat
    Hi guys
    I have galaxy S2 ,It is almost OK except the heat that it produces epically when I play HD games or I use huge applications
    is there an option that should be closed in order to prevent the excessive heat ?
    Please help me
    Super Moderator 252chevyboyz's Avatar
    North Carolina
    13 times
    jfhrtn
    Welcome to the community. Are you a rooted or stock user? If your a rooted user you can reduce the clock speed of your processor thus reducing the heat that is offput from the processor. Other than that playing such cpu intensive games and apps is going to offput a lot of heat just due to the processor being under stress and on top of that the processor and screen is drawing a lot off the battery which is also causing heat. My D2 can reach temps of 117-119 degrees when I'm putting the cpu under a lot stress. Also the ambient temp of the air around the device may cause heat to build up quicker
    Sent from my Liberated D2
    Droid 2/Liberty 2.0.1/Oc'ed/1.3ghz
    Visit our sister site Droidforums.net for more info
    Android Lurker FATRAY's Avatar
    I have an over clocked Droid 1, I see temps reach 130F running wifi teether. That's when the Internet stops working . I put the phone in the freezer for a few minutes and all is good again.
  1. S2 touchscreen - heat only? help please
    By pia2989 in forum Samsung Galaxy S2
    Last Post: 10-09-2011, 03:23 PM
  2. cases cause heat issues?
    By Wickerman in forum LG Ally Accessories
    Last Post: 08-31-2010, 08:39 AM
how to decrese the heat in galaxy s2
how to lessen the heating of galaxy s2
how to minimize heat with samsung galaxy s2
how to minimize the over heat of galaxy s2
how to recude samsung galaxy s2 heat
how to reduce heat in samsung galaxy s2
how to reduce heat on galaxy s2
how to reduce heat on samsung galaxy s2
how to reduce heating in samsung galaxy s2
how to reduce heating samsung galaxy s2
how to reduce the heat of samsung s2
how to reduce the heat of smasug galaxy s2 while playing games
s2 cpu reducing heat
samsung galaxy s2 overheat
sansung galaxy s2 overheat
