What's killing my battery?
This is a discussion on What's killing my battery? within the Android Forum forums, part of the Android Discussions category; I'm going through my battery like crazy. Just talking in forums will completely drain this battery in about 4 hours. I normally keep auto-sync off, ...
Thread: What's killing my battery?
    Columbia, Misery (Missouri)
    8 times
    I'm going through my battery like crazy. Just talking in forums will completely drain this battery in about 4 hours. I normally keep auto-sync off, screen brightness at 30%.
    Sent from my SGH-T499 using Tapatalk
    Android Jr Member mtwd's Avatar
    Apr 2011
    Melbourne Australia
    From your image it looks like the biggest drain is the search for the phone and wifi signals. There isn't a lot you can do about that while using it. I have noticed the drain is greater when out of range, so putting it on flight mode when out of range of a signal may help if that happens. Actually my battery usage looks similar to yours other than display which is a lot higher because I just pulled it out of my bag and found that it was on.
    8 times
    Thank you mtwd.
    Android Lurker takatr29's Avatar
    Nov 2011
    Titanoman and mtwd may I suggest a Anker battery? I have a htc sensation and I was having the same problem with my battery but mine would only last about 2 hours. You guys should really go check out some reviews about the Anker battery if you haven't already did so, you get about 3 more hours of talk and play time, they have them brand new on eBay for around 15 bucks.
    8 times
    Quote Originally Posted by takatr29 View Post
    Thanx for the suggestion. I'm going to check that out right now because this is ridiculous. 15 bucks sounds real good.
  1. Killing applications - DEAD
    By El_Patron in forum HTC Droid Incredible 2
    Last Post: 07-14-2011, 06:37 PM
  2. Replies: 3
  3. App killing with Froyo
    By gilly6868 in forum LG Ally Help
    Last Post: 03-28-2011, 06:13 AM
  4. killing useless apps
    By wi11iam in forum LG Ally Apps
    Last Post: 09-22-2010, 07:15 PM
android forum
ehat is killing my battery
samsung flight 2 battery drain
sght499 samsung
the battery in my samsung transformer only last for about a hour whats wrong
what is killing my android battery
what is killing my android phone battery
what is killing my battery
what is killing my battery android
what is killing my battery on my android
what is killing my phone battery
what's killing my android battery
what's killing my battery
what's killing my battery android
whats killing my droid incredible battery
