MMS help!!!!!
This is a discussion on MMS help!!!!! within the Android Forum forums, part of the Android Discussions category; I have one of those unlocked Samsung Galaxy Notes and I had to change the APN settings found online in order to get the phone ...
Thread: MMS help!!!!!
    Android Lurker patdesignsinc's Avatar
    Jan 2012
    MMS help!!!!!
    I have one of those unlocked Samsung Galaxy Notes and I had to change the APN settings found online in order to get the phone to work with AT&T. I have also installed Go SMS for texting. I noticed that most of the time when I try to send an MMS picture it doesn't go through. It just shows the arrow indicating that it's working (or the spinning wheel if I try to use Samsung's message application.) Can anybody help with this?
    Sent from my GT-N7000 using Android.net
    Super Moderator CJM's Avatar
    MS Gulf Coast
    51 times
    No need to post more than once. I'm going to close this one. If anyone would like to help, they can go here: MMS Help!!!!
att mms settings for galaxy note
galaxy note how to send mms
galaxy note mms
galaxy note mms att
galaxy note mms problems
galaxy note mms setting
how do i send mms on galaxy note
how to send mms on galaxy note
how to setup mms on galaxy note
mms galaxy note
mms issues with samsung note
mms on galaxy note
mms settings for at&t galaxy note
sending mms on galaxy note
why is att mms not working
