Battery Life
This is a discussion on Battery Life within the Android Forum forums, part of the Android Discussions category; Originally Posted by stevemcgee I wo uld like to share some tips to increase the battery life of Android: Set display brightness to adjust automatically, ...
Results 11 to 14 of 14
Thread: Battery Life
    Android Lurker makabebe's Avatar
    Mar 2012
    Quote Originally Posted by stevemcgee View Post
    I would like to share some tips to increase the battery life of Android: Set display brightness to adjust automatically, Disable Adobe Flash and Reduce e-mail, Twitter, and Facebook polling.
    how to disable adobe flash ?
    Android Lurker emptyshell's Avatar
    Mar 2012
    Quote Originally Posted by makabebe View Post
    You should be able to disable it in your browser settings or just uninstall the plug-in.
    Android Lurker mavin's Avatar
    Nov 2012
    i just installed Optimal Battery Saver.... doesn't forceclose apps..
    just regulates network usage. Works well on my samsung S
    Android Lurker superfly's Avatar
    Sep 2012
    Merrillville, Indiana
    Yep. Just keep the number of apps and running functions to a minimum when you're looking to conserve battery life. It sucks that you have to do this, but that's the way it is for now, I guess.
  1. Replies: 1
    Last Post: 08-09-2011, 01:33 PM
  2. Battery life
    By shortysback10 in forum LG Ally
    Last Post: 11-23-2010, 11:46 AM
extended battery for ph44100
free battery savers for andriod smart phone p505
how can i preserve battery power lg p505
htc android ph44100 extended life battery
htc ph44100 battery long life extended
htc ph44100 battery save app
htc ph44100 extended battery
ph44100 battery
ph44100 battery life
ph44100 battery problems
ph44100 htc sprint battery
ph44100 htc sprint extended battery
sprint htc ph44100 battery life
stronger battery for the htc ph44100
