Battery Life
This is a discussion on Battery Life within the Android Forum forums, part of the Android Discussions category; So im still a lil new to these forums andi been lookin round the best i can butdo battery savers and task killers actually work ...
Results 1 to 10 of 14
Thread: Battery Life
    Android Lurker FukoLuko's Avatar
    Jan 2012
    WI
    Battery Life
    So im still a lil new to these forums andi been lookin round the best i can butdo battery savers and task killers actually work to extend battery life if so which ones work good i have a task killer and ive modified all the auto sync settings and so on but it just doesnt seem like helps really any help or just pointing me to s thread i can comb over
    Sent from my PH44100
    Android Jr Member LilTortillaBoy's Avatar
    Riverside, CA
    Task killers aren't a help at all. The only thing they are good for in my opinion is to kill a single app that is acting up. Other than that I would listen to the previous post before me. B-). I hear that juice defender(free) in the market works decently enough. I think its worth a shot if your interested?
    Android Jr Member mamawm's Avatar
    mississippi
    14 times
    the best thing you can do to help save battery on an android device, is pay attention to widgets and apps that constantly update. stuff like facebook and any weather widget. set them to never update, they will automatically update when you launch the app.
    Android Lurker Andyroid's Avatar
    Dec 2011
    3 times
    Also, make sure Wi-Fi and Bluetooth are turned off when not in use.
    Sent from my LG-P505 using Android.net
    Dec 2011
    3 times
    Live wallpapers will kill your battery, too. Battery managers can tell you what is using your battery power and some task managers tell which apps are (misbehaving) in the background, which can be handy.
    Android Lurker chrisjrkim's Avatar
    Jan 2012
    LA
    I also heard that if you have something like google maps up and running, that can drain your battery really quickly. Also turn vibrations off.
    Android Lurker ladymomo's Avatar
    Feb 2012
    Quote Originally Posted by jason0100 View Post
    Do not forget to turn off Bluetooth when using.
    Yes! You should do it!
    Android Lurker cheapdanny's Avatar
    Agreed... bluetooth is a battery killer.
    Banned garagedroid's Avatar
    Nov 2011
    For battery life there is also a very informative post on XDA about Depth of Discharge for extended batteries.
    Worth to give it a look for general use infos.
    Post here
    I have read around, apparently no task killers can compare with extended battery performance. I have battery issues myself, finally bought myself big-muscle-one, I ordered Mugen 3600mAh[HLI-MB855XL] for my Moto; hopefully arrives soon, apparently lasts for couple of days with extremely heavy usage, so i really want to test it now
    Android Lurker emptyshell's Avatar
    Mar 2012
    JuiceDefender works really well.
    I've found the best way to save battery is to limit the apps I install to the ones I use on the go and on a daily basis. Everything else get's installed on my tablet. And if you're rooted and have the option of running a kernel with a battery saving option.
  1. Replies: 1
    Last Post: 08-09-2011, 01:33 PM
  2. Battery life
    By shortysback10 in forum LG Ally
    Last Post: 11-23-2010, 11:46 AM
battery life lg p505
extended battery for ph44100
free battery savers for andriod smart phone p505
how can i preserve battery power lg p505
how to save htc 44100 battery?
htc android ph44100 extended life battery
htc ph44100 battery
htc ph44100 extended battery
lg p 505 battery use
ph44100 battery
ph44100 battery life
ph44100 htc sprint battery
ph44100 htc sprint extended battery
uld battery life
