Android process failed please help
This is a discussion on Android process failed please help within the Android Forum forums, part of the Android Discussions category; I wake up at 3am to find my phone saying my twitter account has failed to sync, when i try to remove the account and ...
Thread: Android process failed please help
    Android Lurker StarrStarr9410's Avatar
    Jan 2012
    Unhappy Android process failed please help
    I wake up at 3am to find my phone saying my twitter account has failed to sync, when i try to remove the account and re-add it the phone freezes saying the Twitter app is not responding, this has happened before and usually when i just re-boot the phone it works. This time when I tired to turn the phone off it wouldn't work so i just pulled the battery which id also done many times before with no problems. Well since then the phone has been giving me nothing but problems, it won't turn on, it takes a long time to turn on, when it does turn on I get a message like "Android process failed" or "Home activity screen failed" I can not make or receive calls open any apps or do absolutely anything with this phone. It is a Motorola Atrix Re-furb, I've had it not even a year yet, there is no visible damage or water damage to the phone, This all kind of seemed to happen after my boyfriend dropped it pretty hard like a week or so ago but i dont know if that has anything to do with it. Anybody have any answers as to why my phone would be doing this, please help.
    Android Jr Member mamawm's Avatar
    mississippi
    14 times
    i wish i had a quick easy solution for you, but this is a new one for me. so i'm going to give you a link to 2 of our sister sites so you can see if anyone else has had this issue with their atrix.
    AT&T Android Forum
    and Atrix Forum - Motorola Atrix Forum
  1. Android: The Process Com.Android.Phone Has Stopped Unexpectedly
    By pod.love in forum LG Ally Hacking / Development
    Last Post: 04-18-2012, 06:37 PM
  2. Process.com.android has stopped unexpectedly?
    By rriles in forum Samsung Epic 4G Tech
    Last Post: 12-28-2011, 11:57 AM
  3. Replies: 1
    Last Post: 07-13-2011, 10:00 PM
  4. Android Acore Process Force Closing??
    By faynay in forum HTC EVO 4G Tech Support
    Last Post: 08-04-2010, 12:05 AM
android process fail
android process failed
android process fails
androidwithlove
androidwithlove force close
com.android.phone process failed
motorola com process failed
my motorola atrix screen says process com.android.phone is not responding
process com failed android phone
process com.android failed
s4 com.android.phone failed
samsung account not sync and result is procesing failed
samsung account process failed
tmoblie phone says android failed
when call android it says android application fail
