Need Help Restoring Data!!
This is a discussion on Need Help Restoring Data!! within the Android Forum forums, part of the Android Discussions category; On my LG Optimus S phone,I was switching my SD Card to check something,but when I put the original back in the apps that I ...
Thread: Need Help Restoring Data!!
    Android Lurker prome's Avatar
    Mar 2012
    Question Need Help Restoring Data!!
    On my LG Optimus S phone,I was switching my SD Card to check something,but when I put the original back in the apps that I saved to my SD card were gone,in addition to some media because I had that saved on my SD card also.
    I think that I might have had something pressed on the phone at the time which may have accidentally formatted the SD card.
    i also noticed that the Apps are there but they do not have their Icons.
    Do you have any Idea on how I would fix this problem?
    Here are some screenshots.
Size:  10.8 KBName:  2012.03.16-12.03.02.jpg
    Mar 2012
    So seriously no one has any input on this?
    Can someone at least say something?
    520 times
    Hi Prome - sorry you haven't gotten any responses so far, but *I* am not a tech, and I'm unfamiliar with LG phones, to boot .
    Just didn't want you to feel totally ignored.
    Super Moderator RobKort's Avatar
    Apr 2012
    Pennsylvania, US
    75 times
    If you formatted the card there is probably nothing to be done there.
    Sent from my MB860 using Tapatalk 2
    Apr 2012
    230 times
    Actually, if you haven't overwritten any data on it, there are plenty programs that can retrieve your files. But only if the files' "slot" wasn't taken by new files. The only program that pops on my mind at this moment is Recuva. It's not the best of all but it does the job. You can find more of such programs on Google, just type in its function.
    There are also some apps on Google Play that let's you do that directly on the phone, but they're not very reliable. I just suggest you connect to your PC and use Recuva (or another on PC).
    Keep in mind that you mustn't overwrite anything, and before you download ANYTHING, do as I suggested.
    When people run in circles,
    it's a very very mad world.
    Tears for Fears
    ~~~ Guidelines of Conduct ~~~
    Somewhere on Kamino
    83 times
    It is also important not to remove sd card without unmounting the sd card it may mess up info on card.
    Apr 2012
    230 times
    Yes, that's also important.
    Tears for Fears
  1. Replies: 1
    Last Post: 01-19-2012, 08:08 PM
  2. Replies: 13
    Last Post: 01-26-2011, 09:12 PM
  3. Data Overages
    By Drewtorrespr in forum HTC EVO 4G
    Last Post: 07-16-2010, 03:09 AM
  4. Data use
    By jak89 in forum Sprint
    Last Post: 07-02-2010, 01:20 PM
android forums
faceniff
how to restore market app on samsung infuse
market app for samsung infuse
optimus s restore apps from sd card
