WiFi in Place of 3G or 4G?
This is a discussion on WiFi in Place of 3G or 4G? within the Android Forum forums, part of the Android Discussions category; There is no way of making calls or text without an application service. -end of line-...
Results 11 to 20 of 22
Like Tree2Likes
Thread: WiFi in Place of 3G or 4G?
    Super Moderator RobKort's Avatar
    Apr 2012
    Pennsylvania, US
    73 times
    -end of line-
    340 times
    Quote Originally Posted by RobKort View Post
    -end of line-
    Yeah, that was my thinking too. Thanks Rob!
    Android Lurker Kid.Anarchy87's Avatar
    Apr 2012
    What applications are good for doing that, text plus costs and I know pinger let's me text with wifi with my main number but what about calling?
    Sent from my Nexus S 4G using Android.net
    340 times
    Kid, if you don't have a signal from a carrier, there is no way to make or receive a phone call.
    Apr 2012
    Then Sprint lied to me? They said there are apps that would allow me calling with wifi if I have no signal.
    340 times
    As I said in an earlier post, I'm no tech expert, but stop and think about it for a minute - If I call you, while you're on wifi only, what phone number am I dialing? By the same token, if you call me and you're on wifi only (no carrier signal at all), what number will be displayed on my phone as the incoming call? If you're asking me, I'd say whoever at Sprint told you that was badly misinformed.
    Android Jr Member Valhalla's Avatar
    Feb 2012
    4 times
    I'm sure if you download skype from the market you could do that but that's with an app. Other wise no. I mean if your out of data reach and in a dead zone and all you have is wifi then very unlikely anything would work. Only way to be sure is if you head out to that dead spot and try and see what happens with useing only wifi. Otherwise you could try roaming.
    Sent from my LGL55C using Android.net
    Feb 2012
    4 times
    Okay here's proof enough. When I make a call or get a call weather I'm on wifi or on 3G etc it takes me off either. It uses standerd 1x so it won't matter if you have wifi or not. If your using just wifi and your in a dead zone then no you can't call or text unless you use apps that uses wifi to do that. The number is whatever the number you sign up with.
    Apr 2012
    Well piss. Thanks for the help.
    Rescue Squad grenefroggie's Avatar
    Apr 2012
    33 times
    You do have an option. It is not cheap. It is called an AIRWAVE Access Point.
    This uses your internet connection to improve you cell phone service in your house. You have the option to use data as well, which makes no sense because you need an internet connection to use it. But it will give you phone service in an area where you can't get it. The retail price for it is $279.99 (plus tax if you have sales tax in your area). There is a discounted price if you have an upgrade of $129.99 (again, plus tax where applicable).
    AT&T has something similar called a MicroCELL. We use one at our office because it is a metal building and you can't get good service. The only time we drop a call is when we go from inside the building outside the building, and vice versa. This is due to losing the connection over the internet and having to switch back to a tower.
    Typically, carriers want you to have at least 3M down to use it. Not sure exactly why. We have customers that use it on 768k/256k, and if traffic shaping (Quality of Service) is done properly it works fine.
    Hope this helps!!
    UltraDroid likes this.
  1. Android Anonymous (A place for all to vent)
    By tp4bama in forum Android Forum
    Last Post: 02-11-2011, 12:07 PM
  2. Hi guys! So happy to find this place
    By Jackie99 in forum Introductions & Site Assistance
    Last Post: 01-19-2011, 06:25 AM
  3. good place for.......
    By davros in forum Android 2.2
    Last Post: 01-18-2011, 09:42 PM
  4. Boy am I going to need this place!
    By Stone in forum Introductions & Site Assistance
    Last Post: 12-16-2010, 07:10 AM
android lgl55c wifi
can't connect to wifi on lgl55c
create a wifi hotspot on lgl55c
end texts without service android
how can i make my lgl55c phone work as a wifi hotspot?
how to enable wifi hot spot on lgl55c
how to make android use wifi instead of 3g
how to text without service on the android
lgl55c wifi hotspot
lgl55c wifi hotspot app
lgl55c wireless hotspot
make android use wifi instead 3g
my lgl55c says its connect to wifi but wont let me get on the internet
text on android without service
wifi hotspot app for android lgl55c
