Micro SD Memory Card Help?
This is a discussion on Micro SD Memory Card Help? within the Android Forum forums, part of the Android Discussions category; Top of the line...
Results 11 to 18 of 18
Thread: Micro SD Memory Card Help?
    Android Enthusiast cd_fifty_6's Avatar
    Overland Park, Missouri
    7 times
    @milkmac9
    Top of the line
    Motorola Droid RAZR MAXX - Droid X2
    Android Lurker Akaash's Avatar
    May 2012
    So which website do you recommend I buy it from?
    And which make would you recommend?
    Sent from my HTC Desire HD A9191 using Android.net
    7 times
    @milkmac9
    i always reccomend sandisk, you might get a good buy on amazon
    197 times
    FurryVarmint
    SanDisk has the best reputation in the Android world because their Class 4 cards are the BEST for running a ROM in devices that you can run a ROM from the SD card instead of the internal memory. However, when it comes right down to it, in daily use there is little-to-no difference between brands (assuming you buy NAME BRAND and not an unbranded card) in performance. Indeed, moving from a Class 2 to a Class 10 will net you miniscule performance gains in app performance (if not some level of performance degradation), but the data transfer rates and recovery time between photographs will be far better with a higher-class card. It all comes down to what you want to do.
    MicroSD cards are like most things -- you get what you pay for. As previously stated, consider Amazon.co.uk for your order as you might get lucky. Cheers!
    DO NOT WRITE IN THIS SPACE
    May 2012
    http://m.mymemory.co.uk/product?p=36561
    Is this is a good memory card, and is it a trusted site?
    I seen this same card on amazon for £30 so thats why I was wondering whether or not it was good.
    Sorry, if these seem like simple questions, I just dont want to get scammed.
    Thanks again for your help guys. Really appreciate it.
    7 times
    @milkmac9
    it looks legit, looks good
    May 2012
    Cheers man thanks, i think i'll probably go ahead and buy this.
    Thank you very much for your help bro.
    7 times
    @milkmac9
    Your welcome
  1. Problem with Micro SD Card
    By robertobrussels in forum Samsung Galaxy Note
    Last Post: 06-19-2012, 12:33 PM
  2. Micro SD Card Speed
    By greybear in forum HTC EVO 4G Tech Support
    Last Post: 02-29-2012, 04:00 AM
  3. saving data on 8 gb micro sd card.
    By vegasman in forum Sprint
    Last Post: 11-22-2010, 01:55 PM
  4. Micro SD Card
    By torchwoodabq in forum LG Ally Help
    Last Post: 10-31-2010, 07:19 PM
  5. Can i use Micro card from blackberry
    By ricoprez in forum HTC EVO 4G Tech Support
    Last Post: 08-22-2010, 06:55 PM
andriod sd storage help
android forum
android forums
android help memory
android memorycard problems
android micro sd card support
android microsd memory faq
android sd storage help
android support for micro sd cards
memory card andriod problem
memory card problems android
my micro memory card problem
samsung note micro sd
search android memory card forums
z4root download
