Micro SD Memory Card Help?
This is a discussion on Micro SD Memory Card Help? within the Android Forum forums, part of the Android Discussions category; Hi, I'm a newbie, so please keep answers simple, try not to get too technical in your answer, thanks. I need some advice on buying ...
Results 1 to 10 of 18
Thread: Micro SD Memory Card Help?
    Android Lurker Akaash's Avatar
    May 2012
    I need some advice on buying a 32gb micro sd memory card for my HTC Desire HD.
    Any recommendations are welcomed along with personal experiences.
    I would like to know which company memory card I should get e.g. Kingston, Sandisk, Lexar, etc. And where to buy it from online or instore which ever is cheaper.
    My friend gave me a 32gb micro sdhc memory card from ebay and it turned out to be a fake. So please, some genuine and trusted sites please.
    Sent from my HTC Desire HD A9191 using Android.net
    Android Enthusiast cd_fifty_6's Avatar
    Overland Park, Missouri
    5 times
    @milkmac9
    i always used a 16gb sandisk and it always worked fine in all of my devices, i got it from wal-mart
    May 2012
    Thanks for your reply, I'm from the UK so I obviously wouldn't be able to visit the wal-mart store.
    Do you mind if I ask how much you brought it for?
    To get a rough idea on how much to get one for.
    5 times
    @milkmac9
    I'm sorry but, I don't know, I think it was around $15-$20, my mom bought it for me, I'm sure the price is different now, she bought it in '09
    5 times
    @milkmac9
    Some of them are higher class which means they have faster read/write speeds, and that soil change the price alot
    5 times
    @milkmac9
    I am using a class 2, but it goes up to class 10
    May 2012
    Oh ok, thanks man. That's really helped. Cheers.
    El Paso, TX
    56 times
    _B0BB0_
    I've also always used Sandisk. They are getting cheaper. Usually a 32gb microSD will run around $30-$40 USD.
    5 times
    @milkmac9
    i just bought a 16gb sandisk micro sdcard and it was about 25 dollars
    Rescue Squad grenefroggie's Avatar
    Apr 2012
    33 times
    I have a 32GB ADATA class 10 card if you want to spend the $50 on it. Has worked great since I got it. In my opinion, the quality is unmatched. The reason I spent so much: Faster transfers from my phone to my computer and vice versa.
  1. Problem with Micro SD Card
    By robertobrussels in forum Samsung Galaxy Note
    Last Post: 06-19-2012, 12:33 PM
  2. Micro SD Card Speed
    By greybear in forum HTC EVO 4G Tech Support
    Last Post: 02-29-2012, 04:00 AM
  3. saving data on 8 gb micro sd card.
    By vegasman in forum Sprint
    Last Post: 11-22-2010, 01:55 PM
  4. Micro SD Card
    By torchwoodabq in forum LG Ally Help
    Last Post: 10-31-2010, 07:19 PM
  5. Can i use Micro card from blackberry
    By ricoprez in forum HTC EVO 4G Tech Support
    Last Post: 08-22-2010, 06:55 PM
andriod sd storage help
android forum
android forums
android memorycard problems
android micro sd card support
android microsd memory faq
desire hd micro sd problems
galaxy note problems with micro sd card
htc desire hd micro sd memory card
memory card andriod problem
micro card help
my micro memory card problem
samsung note micro sd
samsung note micro sd card error
z4root download
