Options for Deleted APN with No Backup, Please Help!
This is a discussion on Options for Deleted APN with No Backup, Please Help! within the Android Forum forums, part of the Android Discussions category; Recently accidentally totally wiped my SD with all my backups before flashing CM9- didn't realize until got the refractory no connectivity and went to flash ...
Like Tree1Likes
  • 1 Post By royfernandez
Thread: Options for Deleted APN with No Backup, Please Help!
    Android Lurker splendiferousjen's Avatar
    Jun 2012
    Recently accidentally totally wiped my SD with all my backups before flashing CM9- didn't realize until got the refractory no connectivity and went to flash a different mod and it (and everything else on my SD) was gone. No backups on my computer either. Is there any option other than reversing my root and taking my phone back to the sprint store to recover my APN or generate a new one? Have an EVO 4G and have been searching the internet like mad but these sorts of questions are generally either unanswered or followed by "oh, I figured it out, I just restored my phone back to xyz". Help/advice is much appreciated.
    190 times
    FurryVarmint
    Hello and welcome to the forum.
    Have you done a search for just the Sprint APN information? If so, please continue to search while we try to get someone who knows what to do to take a look here as soon as possible.
    Sent from my DROID2 using Tapatalk
    DO NOT WRITE IN THIS SPACE
    Android Lurker royfernandez's Avatar
    Apr 2012
    4 times
    ICS blocked the ability for 3rd party apps to edit APN so in order to do it you have to manually edit them in the ROM zip prior to flashing at least that's the only way I've been able to figure out so far since there's no epst for ics yet. You will have to recompile an apk nod it and recompile it and replace it in the rom zip. Another option is to use gosmspro it will allow u to change apn without changing it in the rom so it bypasses the stock settings which is a lot easier for people who aren't familiar with reading and editing code. "APN settings shortcut" links you right to the systems APN menu its not a 3rd party app or a widget so try that and let me know if it works please.
    APN Settings for Android
    Code:
    APN: ggsnint.nexteldata.net
    Proxy  : Blank
    Port : Blank
    Username : Leave it Blank
    Server : Leave it Blank
    MMSC :  MMS
    Proxy : Not Set
    MMS Port : Not Set
    MCC : 302
    MNC : 660
    Authentication type :  Not Set
    APN : Not Set
    furbearingmammal likes this.
  1. Games with Multiplayer Options
    By leandrosrds in forum Xperia Play Games
    Last Post: 01-31-2012, 12:24 PM
  2. Modem options - flash through CWM
    By mletchworth in forum Samsung Captivate Hacking
    Last Post: 05-15-2011, 04:30 PM
  3. options for secure email in Hero?
    By Tadpole in forum HTC Hero
    Last Post: 10-07-2010, 04:10 PM
  4. Clock Options
    By Krissy26 in forum Samsung Epic 4G
    Last Post: 09-13-2010, 09:19 PM
apn delete
apn for sprint on android
apn settings for sprint
apn sprint
delete apn ics
evo 4g apn settings
how to change apn on htc evo 4g
how to delete apn on ics
root edit apn
sprint apn
sprint apn .zip
sprint apn settings
sprint apn settings android
sprint apn.zip
sprint evo 4g apn settings
