My Phone Stuck in Creepy Warning Message!!! Plzz Help by Today!!! :((((((
This is a discussion on My Phone Stuck in Creepy Warning Message!!! Plzz Help by Today!!! :(((((( within the Android Forum forums, part of the Android Discussions category; My phone is Samsung Galaxy S sgh-t959w.and i bought it from moblicity canada.it is runing on android.i haven't done anything to it since i bought ...
Thread: My Phone Stuck in Creepy Warning Message!!! Plzz Help by Today!!! :((((((
    Android Lurker victor536angle's Avatar
    Jun 2012
    My phone is Samsung Galaxy S sgh-t959w.and i bought it from moblicity canada.it is runing on android.i haven't done anything to it since i bought it.But.today,my when i power off my phone,it showed me the
    Warning:
    A custom OS can cause critical problems in phone and installed applications.
    some messages here.
    Volume up:continue
    volume down:Cancel
    you guys probably might know this message.ya..as they said,i try press the volume down button first..but nothing happened..and when press volume up button also,nothing just happened.when i pressed power button,the screen blackout for a while then show the warning message again....it just stucked here already!!!!!i try taking out battery and put again.but no use..just the warning message..so i did some research on internet and i could went into recovery mode..and there 4 options available there:
    1.reboot(it just went back to warning mode)..
    2.apply update from sd card(and there is another problem.i can't go down even i pressed volume down button!!!!but it takes around 15mins to go down!!!WTF>?)
    3.clear data something
    4.clear cache(just using shortly)
    I just bought it 2 weeks ago.!and my mom is going to kill me if i spoil it!!..PLzz help me how to get out
    197 times
    FurryVarmint
    to the forum!
    If you've had it 14 days or less, take it back to the shop and exchange it, assuming you didn't root it or allow anyone to play with it who might have rooted it. If the volume key won't move anything in recovery you probably have a hardware fault and it should be replaced.
    If all else fails:
    Your best bet may be to install Kies and see if there's an update for your phone. If not, you could try ODIN, but if you try to install the wrong thing you WILL brick your phone.
    DO NOT WRITE IN THIS SPACE
    Android Lurker blueapple's Avatar
    Oct 2012
    Question Need help too!
    The same exact thing happen to my phone, it wont even let me go into recovery mode, I'm stuck with it saying warning blah blah. I really need help ! if anyone knows please let me know !
    197 times
    FurryVarmint
    Do you have the same model?
    Sent from my SCH-I535
  1. plzz help. phone wont turn on.
    By allyallyroot in forum LG Ally
    Last Post: 01-01-2012, 11:15 PM
  2. Replies: 0
    Last Post: 09-06-2011, 05:42 AM
  3. Warning Message
    By ltc1919 in forum LG Ally Help
    Last Post: 08-29-2011, 10:59 AM
  4. Phone stuck in reboot loop, shows 50% charged
    By JustPlainLucas in forum Motorola Backflip
    Last Post: 06-12-2011, 11:33 PM
  5. Deliery notification message gets stuck?
    By roseandthorn in forum LG Ally Help
    Last Post: 08-29-2010, 01:57 PM
a custom os can casuse citical problems in phone and installed applications
a custom os can cause critical problems
android custom os warning
android warning message on my galaxy s
custom os warning
custom os warning on phone
galaxy s4 custom os warning
os message on samsung phone
os warning on samsung galaxy 4
warning a cusom os
warning a custom os can cause critical problems
wat is een custom os warning
what is a custom os for android
what is wrong when you have a samsung4 and it has a warning custom cos
why os my phone giving me a warning when i reboot it
