[APK] WiFix - Fixes Regional Wi-Fi Problems in IceCream Sandwich
This is a discussion on [APK] WiFix - Fixes Regional Wi-Fi Problems in IceCream Sandwich within the Android Forum forums, part of the Android Discussions category; Original Source And Thanks: fardjad@XDA Please Thanks Him at His Thread If It Work For You Description I recently found out many people in certain ...
Thread: [APK] WiFix - Fixes Regional Wi-Fi Problems in IceCream Sandwich
    May 2012
    Lost In The Internet
    87 times
    It's a bird
    Description
    I recently found out many people in certain countries no matter what kinds of devices they're using, have issues with WiFi when SIM-Card is inserted.
    I searched a little bit and realized that changing the Wifi country code in Secure system settings should solve the problem and finally made an APK for doing so automatically on phone boot and network state change events.
    Download
    You can download it and follow the updates here.
    You can also download and install WiFix Manager from Google Play.
    Make sure to rate the application.
    Installation
    It's pretty easy; First of all you should have your phone rooted. Then install WiFixManager.apk on your device (Note that I also attached WiFix.apk which is for ROM cookers. You only need to download WiFixManager.apk)
    Start WiFix Manager from applications menu and tap Install WiFix (allow SuperUser permission.)
    Once installed, you're ready to go. The application will change the country code when needed. You can also invoke it manually by dialing *#94349# (*#WIFIX#) and pressing the call button (don't forget to press call button; it's not a MSL code).
    Updates
    I will release updates to this tool when needed, you can easily check for updates and install them via WiFix Manager.
    I'll be glad if you test this tool and tell me your opinion, report bugs, suggest features, etc. either by sending me Emails, PMs, or posting replies in this thread.
    Known Issues
    Sometimes when you reboot your phone with WiFi turned on, you won't have internet access (you can't open webpages, download files etc.) even though it says it's already connected to your router.
    This issue can be fixed by turning WiFi Off and On or dialing *#WIFIX# as described before.
    Recovery Flashable ZIP
    As requested, here's an alternative installation method, Recovery Flashable ZIP file.
    You can download it here.
    For ROM Cookers
    By placing WiFix.apk into /system/app folder you'll have a WiFix enabled ROM.
    If you're publishing that ROM, please include a link to this thread
    WiFix.apk can be downloaded here.
    Android Lurker kiavash599's Avatar
    Jul 2012
    Unfortunately WiFix Doesn't work on Live with Walkman (WT19i)
    I checked it with and without SIM
    Doesnt work on my wireless modem but worked when it connects to my laptop via Adhoc.
    Kiavash Rocky
    Thank You
    May 2012
    87 times
    It's a bird
    Welcome to the forum
    Great to have you with us
    Quote Originally Posted by kiavash599 View Post
    I believe you're running ICS with root.
    Feel free to update/feedback fardjad at his original post as for him to get the fix.
    Jul 2012
    Quote Originally Posted by Astrix View Post
    thnx for reply but no, i already rooted ROM
  1. Galaxy s2 icecream sandwich apps crashing HELP
    By gt11990 in forum Android Forum
    Last Post: 06-04-2012, 08:37 PM
  2. Replies: 0
    Last Post: 04-02-2012, 11:30 AM
  3. ASUS Fixes Transformer Dock Problems
    By dgstorm in forum Android News
    Last Post: 05-19-2011, 01:10 PM
  4. Epic 4G receives OTA, gets Media Hub, bug fixes.
    By droidhead in forum Sprint Android News
    Last Post: 09-20-2010, 08:50 AM
download wifix apk
download wifix for android
download wifix manager apk
wifi fix apk
wifi fix manager apk
wifi repair apk
wifix apk
wifix apk download
wifix apk free download
wifix manager
wifix manager apk
wifix manager apk download
wifix manager.apk
wifix.apk
wifix.apk download
