Help with Data Saver
This is a discussion on Help with Data Saver within the Android Forum forums, part of the Android Discussions category; Updated to ICE on razr now I cant turn off (uncheck) data saver. Its data monitor not data manager in settings. Where did it go....help!!! ...
Results 1 to 8 of 8
Thread: Help with Data Saver
    Android Lurker marvink9's Avatar
    Jul 2012
    Sent from my DROID RAZR using Android.net
    197 times
    FurryVarmint
    What's the issue in daily use? And I'm not trying to be mean, I don't have the phone so I'm unsure what the problem you're experiencing is. Explain it so I can try to figure out something that won't force you to factory reset your phone.
    Sent from my SCH-I535
    DO NOT WRITE IN THIS SPACE
    Jul 2012
    So the issue is..when I go to send an email with some attachments say ....over 6 meg which I need to do quite often i get a pop up that says "to save data this e-mail will not send until it is in range of a wifi". No other option. Anything under about 6 meg it gives me the option to send or wait. Before 4.0 I could go into data manager and uncheck data saver. That option is now gone.???
    197 times
    FurryVarmint
    When you hit the menu button when the data monitor do you get any new options?
    Android Lurker Cmurd23's Avatar
    Jul 2012
    My issue is I don't even want it to ask if I want to "send or wait". I am not worried about sending 2 MB emails and just want the message to stop popping up.
    I wonder if it has something to do with the type of email, being that the message didn't show up when I sent a Gmail.
    197 times
    FurryVarmint
    This new thing is because they're trying to show that they care about people going over their meagre 1-2GB allowances now, especially with the "Share Everything" plans rolling out.
    Jul 2012
    Open email program -> settings -> account name (below "general") -> under data usage unclick "Sync over Wi-Fi only". Maybe that will help.
    I still want to get rid of the dang message!
    Jul 2012
    Anyone else having this issue.... reeeeeally a pain
  1. Can't Find Power Saver Mode ?
    By solorize in forum HTC Sensation 4G
    Last Post: 07-10-2012, 05:58 AM
  2. Replies: 0
    Last Post: 06-26-2012, 10:45 AM
  3. set wallpaper/screen saver but...
    By MrAsian in forum Android Forum
    Last Post: 05-09-2011, 11:57 AM
android data saver mode
android phone data saver
data saver android
data saver droid maxx
data saver mode
data saver mode droid razr
data saving mode
droid maxx data saver
droid maxx data saver mode
how to disable data saver android
how to disable data saver mode
how to turn off data saver mode
how to turn off data saver on razr maxx
razr data saver mode
turn off data saver mode droid razr
