How to Use USB Bluetooth in Android
This is a discussion on How to Use USB Bluetooth in Android within the Android Forum forums, part of the Android Discussions category; Hello. I have device tha doesn't have internal bluetooth. I would like to install external usb bluetooth. Which files ( permissions,libs,apps) I need to copy ...
Like Tree2Likes
  • 1 Post By chimerax
Thread: How to Use USB Bluetooth in Android
    Android Lurker Nicolas1390's Avatar
    Aug 2012
    Smile How to Use USB Bluetooth in Android
    Hello.
    Which files ( permissions,libs,apps) I need to copy into the system to allow connecting this device?
    Thanks
    Aug 2012
    Thank you.
    But, I do not want to write a program!
    I just want to use the external Bluetooth in Android.
    Please help me.
    Android Lurker chimerax's Avatar
    Jul 2012
    2 times
    Does your Android device recognize your Bluetooth device? If not, you need a driver to use it with your Android device. Android version 3.1 and above only supports external Bluetooth devices. Not all the Bluetooth devices support Android devices. There are only a few Android compatible Bluetooth devices available in the market. There are lots of Bluetooth File transfer apps available in Google play. Download a Bluetooth app and try to use it with your Bluetooth device. Bluetooth File Transfer is a very good app. Transcend Bluetooth Dongle is compatible with Androids I think.
    Nicolas1390 likes this.
  1. Replies: 3
    Last Post: 04-15-2012, 07:33 AM
  2. Android and Bluetooth
    By hsm42 in forum Android Forum
    Last Post: 04-04-2012, 01:18 PM
  3. Replies: 0
    Last Post: 01-15-2011, 02:38 AM
  4. How do you fix the no Bluetooth in android 2.1 rom
    By michael29517 in forum Motorola Backflip Development & Hacking
    Last Post: 09-30-2010, 02:56 PM
android bluetooth dongle
android bluetooth dongle app
android bluetooth dongle driver
android bluetooth driver
android bluetooth usb
android usb bluetooth
android usb bluetooth driver
bluetooth dongle android driver
bluetooth driver android
bluetooth driver for android tablet
bluetooth drivers for android tablet
how to use a usb bluetooth adapter on android
install bluetooth dongle on android tablet
usb bluetooth android
usb bluetooth for android
