OEM/3rd Party Micro USB Chargers - How much does amperage really matter?
This is a discussion on OEM/3rd Party Micro USB Chargers - How much does amperage really matter? within the Android Forum forums, part of the Android Discussions category; Well, how much? I've been reading around a bit, because I need at least 2 new chargers, and it seems like there's a lot of ...
Like Tree1Likes
  • 1 Post By CR6
Thread: OEM/3rd Party Micro USB Chargers - How much does amperage really matter?
    Android Lurker BoostMobile's Avatar
    Nov 2012
    Well, how much?
    I've been reading around a bit, because I need at least 2 new chargers, and it seems like there's a lot of conflicting information.
    Also, do they all have the same Input specs? Everything seems to be 100-240v @ 50-60Hz, 120mA.
    The outputs, however, all seem to be 5 volts, with varying amperage.
    I'm getting a new phone by Monday - most likely the GS3 - and I don't want to take ANY risks of damaging the batteries life, charge capacity or ability to hold a charge.
    Thanks in advance!
    518 times
    Your phone WILL come with a charger - use that and you'll have no problems.
    Android Lurker terrywan's Avatar
    Nov 2012
    China
    the best charger is connect your the USB through your PC, because PC power is better than any charger
    Super Moderator CR6's Avatar
    Idaho
    224 times
    Not sure where you heard that. Your phone will actually charge a little faster plugged into the wall. At least that's always been my experience with the smartphones I've owned. You get a slower charge through you pc because it's going through a secondary device instead of directly to your phone.
    tap'n
    Nov 2012
    China
    but PC Electric current is stable than any charger, it keep your li-battery long life
    Android Jr Member ELL4EVER's Avatar
    UK
    I agree with CR6, I sometimes charge my phone using my usb cable plugged into my pc/Xbox and it's alot slower than from a plug socket.
    Sent from my GT-I9100 using Android.net
    Posted from my epic galaxy S2 ^_^
  1. Replies: 0
    Last Post: 07-24-2012, 12:01 PM
  2. Solar Powered Battery Chargers for the Epic?
    By BonnieW in forum Samsung Epic 4G
    Last Post: 08-10-2011, 04:05 PM
  3. Crazy deals on Amazon... 32gig micro SD, micro HDMI
    By cpnichols in forum HTC EVO 4G Accessories
    Last Post: 06-13-2011, 11:24 AM
  4. Specs Still Matter (Or: iPad 2 vs. Motorola Xoom)
    By wicked in forum Android Forum
    Last Post: 03-03-2011, 04:21 PM
samsung s4 oem charger vs 3rd party
third party vs oem chargers
