Android Wireless Charging Options: Nokia Fatboy Pillow and Others (Updated)
This is a discussion on Android Wireless Charging Options: Nokia Fatboy Pillow and Others (Updated) within the Android Forum forums, part of the Android Discussions category; Nokia Fatboy Charging Pillow The pillow (made by Fatboy) is high quality. Filled with a soft material, the material feels great and the seams are ...
Thread: Android Wireless Charging Options: Nokia Fatboy Pillow and Others (Updated)
    Android Jr Member webbjames's Avatar
    Nov 2012
    NewYork
    2 times
    The pillow (made by Fatboy) is high quality. Filled with a soft material, the material feels great and the seams are sewn very well. The Fatboy Charging Pillow comes in a few colors: yellow, blue, white, red, and black and you can get it at Verizon and AT&T stores for around $60.
    To get the charge start, simply drop your wireless-ready phone in the middle and it begins to charge. The feeling is incredible. There are no beeps or notifications, so you'd better to double check to make sure it's charging while you are using it for the first time.
    Nokia Wireless Charging Plate
    The plate is made of plastic, and the color is exactly like the phone. It also comes in blue, yellow, red, white and black, while retailing for around $50.
    It may be my choice if I had to choose one between them. Itís small and convenient, does the trick, and also comes equipped with the extra-long power cable. I favor this over the pillow.
    To charge, just simply lay your phone on it, centered over the Nokia logo. It is very easy to use. It also has a rear LED light that notifies you that your phone is charging.
    LG Mobile WCP400 Wireless Charging Orb Nexus 4
    News from androidcentral report that Nexus 4 charging orb listed online from Pure Mobile for $60, but it's out of stock. Now I have verified the link and find it is available now. So for those who says that charging plate and pillow may not work all that well with the Nexus 4, go to puremobile website to have a check.
    Source from: Android Wireless Charging Options: Nokia Fatboy Pillow and Others (Updated) click to view more.
    Android Jr Member rafnes's Avatar
    Jul 2012
    The Fatboy Pillow seems to be a good option for wireless charging. Moreover the option that our phone will be up on a soft pillow rather than a "plate", would be a nice way to keep it more scratch free. I
    Nov 2012
    NewYork
    2 times
    Quote Originally Posted by rafnes View Post
    I totally agree with you,guys.
    Android Lurker ring2013's Avatar
    Feb 2013
    No other words, Nokia is my favorite phone manufacture.
  1. LG Mash-Up: Wireless Charging & New Product Teaser
    By dgstorm in forum Android News
    Last Post: 02-06-2013, 04:31 PM
  2. Replies: 0
    Last Post: 01-17-2013, 12:08 PM
  3. Replies: 2
    Last Post: 12-29-2011, 11:45 PM
  4. Replies: 0
    Last Post: 04-19-2011, 01:19 PM
  5. HTC Evo 4G Powermat (wireless charging)
    By Cedric in forum Sprint Android News
    Last Post: 10-26-2010, 03:36 PM
