VOIP Problems
This is a discussion on VOIP Problems within the Android Forum forums, part of the Android Discussions category; I have HTC One S. I had downloaded Voip about 1 month Back. But then the quality seems to be really bad. Is this due ...
Thread: VOIP Problems
    Android Jr Member rafnes's Avatar
    Jul 2012
    VOIP Problems
    I have HTC One S. I had downloaded Voip about 1 month Back. But then the quality seems to be really bad. Is this due to wifi or is it the prob of voip? Are there any similar applications for long distance calls ?
    Android Lurker Whislameron's Avatar
    Oct 2012
    Quote Originally Posted by rafnes View Post
    You can try Switch2Voip to make calls from any mobile phone using a VoIP app, just configure it with the username, password and IP provided by the VoIp provider, the website is Voip for Call Centers, Sip Trunks, Free USA DID, Toll Free Numbers - Switch2Voip
  1. Voip
    By hbboarder87 in forum Nexus One
    Last Post: 05-19-2011, 06:02 AM
  2. Sip & voip
    By alanudi in forum Nexus S
    Last Post: 12-07-2010, 05:39 AM
