LG G2X stuck at start-up
This is a discussion on LG G2X stuck at start-up within the Android Forum forums, part of the Android Discussions category; Ok i downloaded Rom manager so i could go in to the phone and hard reset it. After i did that and hit restart it ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Like Tree1Likes
Thread: LG G2X stuck at start-up
    Android Lurker Slayer8869's Avatar
    Mar 2013
    Unhappy LG G2X stuck at start-up
    Ok i downloaded Rom manager so i could go in to the phone and hard reset it. After i did that and hit restart it came back on and the LG screen pops up then goes black and then sits there and does nothing but u can see that its still on its like the brightness keeps going bright then dim then bright over and over and over.
    If anyone could help it would be very appreciated.
    Its the only phone i have and im unemployed so i do not have money to get another one.
    Apr 2012
    230 times
    Hello and welcome to Android.net Forum, Slayer!
    You don't need ROM Manager to hard reset it. There's an option in the Settings.
    Now what you have to do is go to the Recovery mode via ADB. Then you can do the hard reset again to fix it.
    For ADB to work, you'll need your phone's USB drivers on your PC, you can get them from the manufacturer's website or Android SDK from here. You will need Android SDK anyway, because it contains the ADB.
    If you don't know how to operate ADB, then just open up the command line from the start menu by typing "cmd" in the search field. Once it opens up, type "cd", press space and enter the location of the ADB. It should look like this:
    Code:
    cd C:\Program Files\Android\adt-bundle-windows-x86_64\sdk\platform-tools
    Hit enter, then type "adb", press enter again, then type this command:
    Code:
    adb reboot recovery
    Your phone should reboot into the Recovery Mode and you'll be able to do a hard reset.
    To check if ADB recognizes the phone, type this command:
    Code:
    adb devices
    If it does, it'll show you the serial number and "device", if it doesn't, it'll show you nothing or "offline".
    Good luck!
    Tears for Fears
    ~~~ Guidelines of Conduct ~~~
    Mar 2013
    I tried it and it dont work and i went and looked in the program files and theres no file that says android.
    Apr 2012
    230 times
    Wait, have you downloaded the SDK? If so, you also need to install the components. You can install them from the SDK Manager.
    Tears for Fears
    519 times
    Slayer, in the future you want to be careful with Rom Manager. It can be quirky at times and has been known in the past (granted, with an OG Droid, not an LG phone) to do exactly the opposite of what you instructed it to do.It's OK to have it around, but I'd try to limit the amount of use I gave it.
    Mar 2013
    Yes i downloaded the SDK and in the SDK manager what should i install? i already installed the tools and the 4.2.2 stuff and it sill hasent changed anything under program files.
    Apr 2012
    230 times
    You need to install everything inside "Tools" and "Google USB Driver" in "Extras". It may not necessarily be in Program Files, it's just a default location. All the components are stored where you downloaded the SDK. Look inside where you found SDK Manager.
    Tears for Fears
    Mar 2013
    When i open up CMD this is what it looks like. Name:  Untitled.jpg
    Mar 2013
    And were i have the SDK file it is in my downloads file so its C:\Users\Mrpaul\Downloads\adt-bundle-windows-x86_20130219\sdk\platform-tools
    But i tried that and it didnt work it says the system can not find the path specified.
    Apr 2012
    230 times
    You forgot to input the "cd" before the location. CMD command line needs to understand what you want. Copy this into the Command line:
    Code:
    cd C:\Users\Mrpaul\Downloads\adt-bundle-windows-x86_20130219\sdk\platform-tools
    And make sure you carefully follow the instructions.
    Tears for Fears
  1. HTC One X Stuck, Not Starting
    By nilsr in forum Introductions & Site Assistance
    Last Post: 01-03-2013, 11:32 AM
  2. HTC One X Stuck, Not Starting
    By nilsr in forum Rescue Squad Help
  3. Galaxy Gio Stuck
    By Rifleman0007 in forum Rescue Squad Help
    Last Post: 07-09-2012, 02:11 PM
  4. s2 get stuck
    By rooney10 in forum Android Forum
    Last Post: 10-11-2011, 02:10 PM
  5. Stuck or froze???
    By sleepersubie in forum LG Ally Help
    Last Post: 10-21-2010, 09:56 AM
g2x stuck in reboot
how to reset android lg if stuck
lg g2 getting stuck on lg screen
lg g2 lg logo start up
lg g2 not staring up
lg g2 stuck at lg logo
lg g2 stuck at lg screen
lg g2 stuck at logo
lg g2 stuck on lg screen
lg g2 stuck on logo screen
lg g2 will not start
lg g2x stuck on logo
lg g4 android stuck on start up screen
lgg2 stuck in charging modr
my lg g2 is stuck at startup screen
